BIKELAND > FORUMS > ZX-14.com > Thread: Slow speed headshake, what would be the causes? NEW TOPIC NEW POLL POST REPLY
kawpower
Mr kawasaki 2 you!
posted August 03, 2012 01:48 PM
It just started and got worse, slowing down the bars want too shake side to side and when i speed up it goes away,this is on my 06 zx14,any help is appreciated.
hagrid
posted August 03, 2012 03:01 PM
What condition is your front tire? Spun balanced or static?
If the tire isn't the culprit then check steering stem bearings.
blue 14R
Neilp
posted August 03, 2012 03:25 PM
I would put my money on front tyre!
Neil
kawpower
Mr kawasaki 2 you!
posted August 03, 2012 03:58 PM
tyre is in good condition no feathering,spin bal, i will chech bearings ,if it is bearings do they need to be replaced or serviced and adjusted? thanx for the input fellas!
Danno
posted August 03, 2012 04:15 PM
Some bikes show sensitivity to certain tires even when the tires are new. Add that to steep, quick-steering front end geometry and you have a prescription for wiggle.
shawnski
posted August 03, 2012 04:19 PM        Edited By: shawnski on 4 Aug 2012 01:41
does it do when you brake to slow down??
hagrid
posted August 03, 2012 06:04 PM
blue 14R
epd345
Is it possible you lost some wheel weights? Your tire could also be defective.
hagrid
posted August 03, 2012 06:52 PM
Sry for the double post... no idea how the hell it happened.
blue 14R
kawpower
Mr kawasaki 2 you!
posted August 04, 2012 05:41 AM
Thanx guys i will let u know wat i find.
posted August 04, 2012 08:03 AM
Maybe theres a flat spot on the tire ?
Check to see if the rotors are warped?
kawpower
Mr kawasaki 2 you!
posted August 04, 2012 09:41 AM
will do Rick.
Rob7R
More balls than brains.
posted August 04, 2012 10:38 AM
Mine used to do the same thing... i replaced the front wheel bearings, and it took care of the problem.
Current bike- 07 ZX14 black with D&D cans, PC3, 43t rear sprocket, 6 inch extensions, roaring toys lowering links. Muzzy Bonneville Pro, TRE Velocity stacks, Puig DB windscreen, Sargent seat, Heli-risers, and throttlemeisters.
blue07
posted August 04, 2012 11:44 AM        Edited By: blue07 on 4 Aug 2012 18:47
My vote...front tire.Sometimes would 'wiggle' at between 40-50 mph steady speed,or deceleration.Not a shake...a wiggle...very tiny.Tires always cured it.
Quick Reply:
0.212733030319 seconds processing time
