BIKELAND > FORUMS > ZX-14.com > Thread: Lets talk shocks NEW TOPIC NEW POLL POST REPLY
Slowninja
Slow-ride
posted July 29, 2012 11:04 AM
Lets talk shocks
Whats the difference between a gen 1 and a 14R shock?
I have a gen 1 and am interested in putting a 14R shock on my bike.
06 zx14
SWB
9.24 @ 148
posted July 29, 2012 11:46 AM
What are you doing with your bike? Mods? Your weight?
Slowninja
Slow-ride
posted July 29, 2012 12:20 PM
Bike is nothing special. Just 64" streetbike. I have an Ohlins shock on the bike now, leftover from when the bike was a race only bike. It doesn't ride very well on the street. Looking at trading shocks with a friend with a 14R, I just want to make sure the shock will work on the bike and if there are any differences that may make a difference
06 zx14
SWB
9.24 @ 148
1badzx12r
posted July 29, 2012 01:09 PM
http://www.psychobike.com/forums/garage-sale/106947-hyperpro-drag-shock.html
it will fit ..
http://www.youtube.com/watch?v=8rh6qqsmxNs&feature=related
mick46
posted July 29, 2012 01:18 PM
Stiffer spring than gen 1 and more damping apparently, so should work better .
2012 ZZR-1400
Alien Frogskin Green
Brocks CT Meg, PCV & QuickShifter, Brembo M4 Monoblocs, Grimeca 320mm discs, Nitron Race shock, Gilles rearsets , adjusters and TCA axle nut, Supersprox 42T, DID nickel plate X-ring, HEL brake lines, bar risers, shorty levers, tail tidy, Zero Gravity screen, RandG spools and bar ends, GPR V4 damper.... Done !
1999 Hayabusa , stretched lowered and a 60 shot !
zixxer14
Damn that was Quick
posted July 29, 2012 01:50 PM        Edited By: zixxer14 on 29 Jul 2012 20:52
Be aware your Ohlins shock can be rebuilt & revalved to work however you need/want. A properly tuned Ohlins will be superior to any other shock you could pick. Contact them & ask, it usually is not that expensive.
http://www.ohlinsusa.com/
chromedout12r
posted July 29, 2012 02:23 PM
I will give you cash plus my 14r shock for your OHLINS
lietoome
posted July 29, 2012 05:36 PM
I think reworking the shock would would be better than any factory shock.
Quarter Pounder
with Cheese
posted July 29, 2012 06:31 PM
Get your Ohlins serviced and set up properly. You'd be a fool to swap that out with compromised OEM junk.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
Wheelie
Old Man
posted July 29, 2012 06:40 PM
yep.
wee
almost_les
posted July 29, 2012 07:33 PM
if you got any old $100 bills lying around, i can trade you for some crisp fivers
Slowninja
Slow-ride
posted July 30, 2012 04:33 AM
Thank you for all of your opinions.
06 zx14
SWB
9.24 @ 148
justoyz2
Justoyz Racing
posted July 30, 2012 11:35 AM
I assume the shock rides rough, right? The new 14r shock is difficult to slow the rebound and compression down... I have thought of getting it revalved, but looking into getting a JRI
2012 zx14R, 2011 zx10R, 2008 zx10, 2007 zx10 Turbo.....
mick46
posted July 31, 2012 12:48 PM
I have gone for a British made Nitron race shock which has a custom spring (for my 270 lbs) and has a wide damping range (as well as separate hi and lo comp) .
No more wallowing mid corner, no more kicking off ridges,and the option to raise the ride height half an inch or so to speed up the steering and (hopefully) a reasonable drag set-up in there too!
2012 ZZR-1400
Quick Reply:
0.213002920151 seconds processing time
