Thread: 07 zx-14 not getting fuel |
duffmatthew
posted July 09, 2012 12:36 PM
I have an 07 14 that has sat for a few months. I drained the tank and put new fuel in, changed the fuel pump, cleaned the fuel injectors, changed the ecu and disconected the pc3. I am still getting no fuel in the cylinders. I have good presure to the fuel rail but the injectors are not opening. If I put a little starting fluid into the intake it will run for a few seconds and die, so I know I have good compression and spark but no fuel. Is it possible all four of my injectors died at once? Any ideas of what else I can look at?
SixSixoh6
posted July 09, 2012 05:10 PM
Edited By: SixSixoh6 on 10 Jul 2012 00:11
Changed the ECU? Why did you do that?
Beondwacko
posted July 09, 2012 05:37 PM
Are you getting a pulse signal while cranking at any of the injectors, just to help rule out the ecu? Have you done an ohm test to the injectors?
duffmatthew
posted July 09, 2012 05:48 PM
I got it running. The battery was almost dead after changing the ecu. I charged it and she started up with only a little resitance. Thanks for the replies. I changed the ECU because I had eliminated all other posible issues and that is what fixed the problem.
BLK ICE
posted July 10, 2012 08:38 PM
Edited By: BLK ICE on 11 Jul 2012 03:39
Glad you got it fixed
(I am open to Sponsorship and Product Testing and Review. Contact BlackIce Performance at blackice_performance@yahoo.com)
| Quick Reply: |
