Thread: super sport head piston to valve |
joseph702
posted June 24, 2012 01:27 PM
i know to check piston to valve clearince is not tdc but were do i start? any one know around wha degree ? working on it right now so any help would be nice ty .
davisag
posted June 24, 2012 03:00 PM
around 12 degrees before tdc for the ex and 12 degrees after tdc for the inlet, you lookin 1 mm clearance for the inlet and a little more for the ex
joseph702
posted June 24, 2012 03:36 PM
thank u
Y2KZX12R
CompetitionCNC.com
posted June 24, 2012 07:09 PM
+1
I usually find 8-10 BTDC is the closest point on the exhaust and 8-10 ATDC for the intake.
Its best to check it at 6 8 10 and 12. you will see it cet closer and then further.
Piston to valve clearance depending on your springs and the major intensity of the cam grinds. Typical is no less than .040"-.050" on the intake and .050"-.070" on the exhaust.
Stay to the high side if the major intensity is below 24.
Y2KZX12R
CompetitionCNC.com
| Quick Reply: |
