Thread: smokinZX14? |
03SGBUSA
posted May 22, 2012 03:23 PM
smokinZX14?
Did you ever run your zx14r in stock form? what did it run?
posted May 22, 2012 05:35 PM
quote: Did you ever run your zx14r in stock form? what did it run?
I don't thing i rode it ever 100% stock at the track ..I think the first time i had it at the track was with a pipe and strapped ... I know it was right after i had it on the dyno .. Stock oil and 75 miles on the bike it made 197.8 SAE..
mma-tv
posted May 22, 2012 05:57 PM
Does the strap make a noticeable difference? I can NOT keep the front wheel down through first and would love to find a reasonable fix.
posted May 22, 2012 06:00 PM
Yes the strap will make a difference on any bike. Not only are you lowering the center of gravity, your stopping weight transfer/momentum from the front suspension and help keep the front end down
dakota9498
posted May 22, 2012 06:15 PM
quote: Yes the strap will make a difference on any bike. Not only are you lowering the center of gravity, your stopping weight transfer/momentum from the front suspension and help keep the front end down
+1 huge improvement on any bike at the strip.
2008 ZX14
posted May 22, 2012 06:20 PM
Edited By: smokinZX14 on 23 May 2012 01:20
Strap worked pretty darn good on my 06 and 09 zx14 .. But didn't help much with my 2012 ZX14R ...
smokinstorm
Old Drag Racer
posted May 22, 2012 07:31 PM
Edited By: smokinstorm on 23 May 2012 02:32
quote: Does the strap make a noticeable difference? I can NOT keep the front wheel down through first and would love to find a reasonable fix.
Strap is making a big difference on both the 14 @ 71" and the Turbo Busa @ 72" right now. It's hard to believe strapping the front end down would make a difference once a bike gets that long but both will still wheelie if not strapped. Go figure. I thought I'd be able to get away from a strap but it looks like I'll have a strap on the bikes as long as we drag race them.
2009 Monster Edition ZX14
It's all stock I swear. Well...almost.
2005 Turbo Busa
2001 GSXR 1000
Looking for a 1985 GS1150E
Quarter Pounder
with Cheese
posted May 23, 2012 11:37 AM
you can get away from a strap if you alter the internals in your forks.....basically shorten them and have a ton of rebound built into them
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
| Quick Reply: |
