Thread: 180 55 17 shinko hook up |
quikgix
posted May 21, 2012 05:21 PM
Not hookin up on my 14. Just installed 2 weeks ago and this tire is very inconsistent. Anyone else having issues?
1352cc 8.43@158mph on motor cant wait to spray this bitch
posted May 21, 2012 05:27 PM
No problems with mine but i'm using a 190 50 17 ... 18 psi , I do a pretty good burn out and works great ..
01smokes
posted May 21, 2012 05:38 PM
Mine works, but is getting old. but I have a friend that has one on his bike. Maybe 2 weeks old 10 or so passes. And he is spinning bad. He is SWB I'm at 70" Maybe a bad batch of tires this last go round
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
posted May 21, 2012 05:48 PM
At stock wheelbase he should be able to run. 30 psi and never spin.
miketmmns
posted May 21, 2012 06:03 PM
I had trouble with the first one I bought. It would spin pretty bad and only
lasted a couple of race weekends. The last two seem to be doing ok but
I'm switching to the power one after this one wears out.
01smokes
posted May 21, 2012 06:10 PM
quote: At stock wheelbase he should be able to run. 30 psi and never spin.
I ran 32 on mine at SWB he was down to 8 before he put it on the trailer
Bently
2012 14r In Blue and no Mods!
posted May 21, 2012 06:28 PM
We have 5 bikes in our group using them and no issues and all bought at different times. but we set are suspension up well and no one is using a stock shock. we are using them from 61 inches to 69 inches.
Bently
But we all use 190's
BLK ICE
posted May 21, 2012 06:47 PM
Edited By: BLK ICE on 22 May 2012 02:09
hook-up180s have been woking great for us.
what tire did you use that was working?
(I am open to Sponsorship and Product Testing and Review. Contact BlackIce Performance at blackice_performance@yahoo.com)
dakota9498
posted May 21, 2012 07:22 PM
I use a 190, usually run it at 22psi, never an issue.
2008 ZX14
posted May 21, 2012 07:35 PM
I have ran the 180/55/17Michelin power race since 2009 with no problems.
Couldn't find anymore power race, so I got a power one
Meangreen14
posted May 21, 2012 09:12 PM
Get the 50, the 55 is taller... And why are u runing a 180??
PCV, quick shifter, stock gearing,
fly's out, custom garrett gt28 stage1 turbo, JE pistons, 625cc inj, MTC lock up clutch,1:1 fuel pressure regulator...
dakota9498
posted May 22, 2012 05:14 AM
180s weigh less. Some of us are weight nazis.
2008 ZX14
quikgix
posted May 22, 2012 06:33 AM
I have always used the 190 Hook Up,but as Dakota9498 stated, weight nazi's
Meangreen14
posted May 22, 2012 06:53 AM
quote: 180s weigh less. Some of us are weight nazis.
Oh ok, makes sense
1badzx14
08 Turbo zx14!!!
posted May 22, 2012 11:02 AM
just put a slick on it!!!! lol
SixSixoh6
posted May 22, 2012 04:35 PM
used a 003 NON U-soft. hooked perfect every time. 15psi
dakota9498
posted May 22, 2012 06:14 PM
quote: used a 003 NON U-soft. hooked perfect every time. 15psi
Don't think that would work with quikgix's light bike with ported head and a 75 shot. Hell it wouldn't work on my 66" stock motor bike.
2008 ZX14
quikgix
posted May 22, 2012 08:34 PM
I've ran my best 60's with the 190 hook up,so I'll be gettin another one very soon.
posted May 23, 2012 10:56 AM
If the usoft/hookup won't work, then the non usoft damn sure won't work!
BLK ICE
posted May 23, 2012 03:11 PM
Edited By: BLK ICE on 23 May 2012 22:28
I picked up a new tire today from Custom Specialties Cycles http://handlebarheaven.com/csi.html. They recieved a new shipment today. I noticed that the 180s seemed a little drier and harder than the 190s, and the 180s I have gotten from Custom Specialties Cycles in the past. I went with the 190 this time, but I will go back to 180s when I see them at the quality level they use to be.
The internet is not always the best route to go when buying tire IMO. It cost alittle more to buy from your local vender, but you get to see what you are buying before it is at your door step.
If you need a new hook-up give Custom Specialties Cycles http://handlebarheaven.com/csi.html a call. All of their 190s are fresh and of good quality. I checked them all.
Black Ice.
01smokes
posted May 23, 2012 03:36 PM
Do you guys have the dates on the tires that are not working?
CraigChrist
BAWLS
posted May 24, 2012 06:47 AM
I bought one for dad when they first came out. If you are on a great track like dakota runs on (MIR) then there will be zero issues. If you are on a questionable track or don't have your suspension absolutely dialed in then you can hang it up. the hook up won't hook. Dad had better luck out of the full bore and the U-soft than he did with the hookup and that was with him at about 61-62" and weighing 145 lbs. Needless to say, He runs a 008 slick because when the hookup spins, it hooks.
60ft-------1.42
1/8th------5.97
mph-------119
RICH CRAFT 1
posted May 25, 2012 02:49 PM
I will only use the 200 drag radial, and now that it's getting hot traction will be harder to come by. Especially with tracks cutting back on glue!!! it's a quarter inch wider than the 190,and holds a lot better. 1 pound of tire weight doesn't mean much if you just got beat from spinning. most of the time when traction is hard to come by. We run only 8 pounds of air.
Ken
Red 06 ZX14 RR
| Quick Reply: |
