BIKELAND > FORUMS > ZX-14.com > Thread: How much compression NEW TOPIC NEW POLL POST REPLY
tking
posted May 16, 2012 04:56 PM
My head is milled .030 and I run a 40 shot every now and then when at the track. Would 13.5:1 pistons be ok to run?
posted May 16, 2012 05:13 PM
Don't spray with pump gas ...112 or better only ..
tking
posted May 16, 2012 05:33 PM
No I wouldn't, I mean street riding would it be ok with that compression and 93 octane?
posted May 16, 2012 05:37 PM
Oh yes 93 on the street will be fine ..
posted May 16, 2012 06:26 PM
13.5:1 pistons + .030 off the head could lead to CR = 15:1???
that would be pushing pump gas a bit...
BlackMagic14
posted May 16, 2012 06:51 PM
I think you would be ok without the spray depends on what is the highest octane available in your area. 93 would be the lowest I would run. And I agree with Smokin I would stick to the good stuff on the spray. You running stock valve springs?
tking
posted May 16, 2012 06:53 PM
It has carpenter springs in it
posted May 16, 2012 07:15 PM        Edited By: smokinZX14 on 17 May 2012 02:23
He doesn't have 13.5 pistons .. He has stock pistons with the head milled 30 .. No where near 15.1 .. Closer to 13.1
P/S entropy i hope you are feeling better and getting back in to shape ..
posted May 16, 2012 08:26 PM
smokin',
i am slowly getiing back to normal, it's gonna be a long haul... You know what a long haul is i'm sure.
I took his note to mean that hehas milled .030 off the head and is now looking at installing pistons designed to give 13.5:1 (with stock head)
Quick Reply:
0.276262998581 seconds processing time
