BIKELAND > FORUMS > ZX-14.com > Thread: Should I mill it further? NEW TOPIC NEW POLL POST REPLY
tking
posted May 16, 2012 03:12 PM        Edited By: tking on 16 May 2012 22:17
I was having an issue with the head gasket not sealing up good because of the cut on it I"m guessing, Well I took it to the machine shop and they said that it also need exhaust valve guides? This motor has 7k miles on it and was untouched until 2 months ago. So looks like its going to get a valve job too, Should I have them sink the valves in .030 and mill another .030 or maybe even angle mill at it and at least get a little more power out of it? Right now it is cut down .025 This is on a 08 zx14
posted May 16, 2012 05:15 PM
Just skim cut it 5 thou .. Make sure the cut it as smooth as possible ..
08smokes
God is love.
posted May 17, 2012 07:49 AM
.030 is cutting it pretty close. If you miss a shift it could be really bad news. I just had my 08' head milled .020, valve job, 47mm TB's and gained 20 hp. It's best to error on the safe side.
Quick Reply:
0.04088306427 seconds processing time
