Thread: I wanna raise the arse end of my 2010 14, what options do i have? |
tour10
posted May 16, 2012 09:36 AM
I wanna get my back end of my first gen zx-14 up a half inch or so. is anybody making a link that replaces the stock link? i'v thought about an aftermarket penske or equivalent shock but that chews up any where from $750 (used)-$1000 (new). any suggestions are appreciated
mick46
posted May 16, 2012 10:39 AM
Brocks (or similar) adjustable lowering links shortened by 3/4 inch or so would do what you desire
2012 ZZR-1400
Alien Frogskin Green
Brocks CT Meg, PCV & QuickShifter, Brembo M4 Monoblocs, Grimeca 320mm discs, Nitron Race shock, Gilles rearsets , adjusters and TCA axle nut, Supersprox 42T, DID nickel plate X-ring, HEL brake lines, bar risers, shorty levers, tail tidy, Zero Gravity screen, RandG spools and bar ends, GPR V4 damper.... Done !
1999 Hayabusa , stretched lowered and a 60 shot !
atldude
Working on it...
posted May 16, 2012 10:50 AM
Can't you just add a spacer on the upper side of the shock?
Like this: http://s28.photobucket.com/albums/c227/terrano1/zx10/?action=view¤t=P1020074.jpg&sort=ascending
Whichever way you decide to do it, post back when you ride it..
posted May 16, 2012 02:34 PM
I wouldn't think raising the shock would raise the bike up. I thought that would have to be done by the links.
Just curious, why are you wanting to raise the rear up? It's pretty high stock
Wheelie
Old Man
posted May 16, 2012 02:44 PM
better cornering, Gixxer guys have been doing it for years.
wee
Quarter Pounder
with Cheese
posted May 16, 2012 02:53 PM
some drop the yokes on the folks a bit to get the same result...but give up some cornering clearance. I'd rather raise the rear to negate any clearance issues. Ohlins shock fixed it no problem and handling is MUCH better than it was stock. Ride quality is also better...win win.
Only way to raise it is shorter links (adjustable noted above) or a proper shock. IMO, the shock is going to give you more results than just a raised rear end.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
atldude
Working on it...
posted May 16, 2012 03:49 PM
I am not exactly an expert and might just be wrong but i really thought thats how you could raise the rear a lil bit as much as the thread up there allows .. Dunno
Found this and look at the desc: http://item.mobileweb.ebay.co.uk/viewitem?itemId=130689287817
MotoCycho
posted May 16, 2012 05:54 PM
quote: I am not exactly an expert and might just be wrong but i really thought thats how you could raise the rear a lil bit as much as the thread up there allows .. Dunno
The 14 uses an horizontal eyelet type mount on the top of the shock and there is no bracket like you see in the pic you linked, the bolt passes through tabs which are part of the frame casting, so there is no place to insert such a shim.
atldude
Working on it...
posted May 16, 2012 06:50 PM
Ah told you no expert was lookin around for my 10 recently and i remembered this but thanks for setting me straight mate.
dcjens
Wet side of Washington
posted May 16, 2012 10:53 PM
A 3 hole link goes up or down and are cheap
Black 06
MotoCycho
posted May 16, 2012 11:57 PM
Edited By: MotoCycho on 17 May 2012 07:02
quote: A 3 hole link goes up or down and are cheap
On my 3 hole links you get "stock", "lowered" or "more lowered". Maybe Soupy's adjustable links can go shorter than stock links and thereby raise the back. In fact.. you could simply cut off some of the center turnbuckle. The caution with Soupy's links is not to extend them out too far and thereby not have enough threads engaged, but making the center shorter would still provide an ample number of threads to be used. Hell, Soupy's might even be able to sell you a set with shorter turnbuckles ready to go.
tour10
posted May 17, 2012 08:06 AM
unfortunately on the gen 1 zx14's a spacer cant be used, kawasaki used the old zx11 style rear shock mount instead of the 6r/9r/10r/12r mount where a shim or nut could be used.
dcjens
posted May 17, 2012 11:43 AM
been awhile since i looked at mine..my bad.. it is stock..low and slammed
Black 06
| Quick Reply: |
