Thread: 14R: A Little More Less Weight Ideas . . . |
CraZX14
posted May 12, 2012 10:35 AM
Shane covered weight saving ideas extensively in his build thread, but I thought I'd add a couple more things:
Stock seat assembly is around 8 lbs according to my bathroom scales (was too heavy for the food scale). My Catalyst Composite drag seat weighed in at 2lbs, 2oz - so basically a 6 lb drop . . . and for drag racing, you also get the advantage of lowering your center of gravity as well as the weight savings ( Initially, I was not going to use my composite seat on the 14R since the fit isn't exact, and it rubbed on the old '14, but I used a dremel to shave down the areas of concern).
While I had the seat off, I noticed the tool kit, and decided to eliminate that 1 lb 5 oz as well.
The Window Lowering Links (6oz savings - Shane's build thread) can't be reached with the belly pan assembly in place - another 1lb 40z.
So the CT Meg and rear sets gone saves 35.7 lbs. The seat swap, tool kit, lowering links, and belly pan saves approximately 9 lbs. Net loss almost 45 lbs over stock. Just another example of how every little bit helps
2003 L.E. Hayabusa
zx13r
Capt-America
posted May 12, 2012 01:39 PM
Lose the lower bars on the sub frame.
Sposored By:
Kawasaki Sports Center
ShoTime Graphics.com
posted May 12, 2012 01:50 PM
If you look through my old gen 1 build thread you will find most every component on the bike weighed...including the motor. Most of the Gen 1 stuff applies. I would love to make my 14r as light as my gen 1...but i am trying like hell to do the regular street bike thing.
BLK ICE
posted May 12, 2012 02:05 PM
Edited By: BLK ICE on 12 May 2012 21:06
lite tires(for most stock wheel base riders these are good chioces:Michelin power pure front tire - 120/60zr-17 and rear 180/55-17 or power one rear 180/55-17)
(I am open to Sponsorship and Product Testing and Review. Contact BlackIce Performance at blackice_performance@yahoo.com)
| Quick Reply: |
