BIKELAND > FORUMS > ZX-14.com > Thread: Which map ? NEW TOPIC NEW POLL POST REPLY
conn-e-rot ninja
posted May 10, 2012 11:06 PM
Which map ?
I'm trying to sift through all the info on here and decide which map is best to run for 95% street riding with a lot of long distance rides, occasionally I make it to the strip. I am running the brock's street map right now should I just stick with the street map or is the race map a better choice? I had it on the dyno last weekend at a dyno day and tuner said it's a bit rich only pulled 169/97 with 93 octane. I am also do for a valve adjustment would valves out of spec affect my numbers?
'07 stock motor,stock gearing, k&n, full alien head, pc3
2007 zx14
zx12mark
posted May 11, 2012 05:20 AM
if your valves are a little tight you would make more power than if they were a little loose.
posted May 11, 2012 01:57 PM
How many miles on the bike ?
conn-e-rot ninja
posted May 12, 2012 12:02 AM
over 25k
2007 zx14
conn-e-rot ninja
posted May 12, 2012 12:09 AM
I think it runs good now I just wasn't sure if there would any benefit for me to run race map or if I'm better off sticking with the street map. For the little bit I might gain I'm not interested in spending $200-$300 on a custom map Brock's knows their shit from everything I've seen.
2007 zx14
conn-e-rot ninja
posted May 12, 2012 12:13 AM
2007 zx14
0.24802494049072 seconds processing time
