Thread: 14R air filter available yet? |
Lsantana954
posted May 10, 2012 02:34 PM
Anyone hear of an aftermarket air filter available for the 14R yet?
'12 Gully Blue ZX14
-PCV/Guhl ECU/Blue CT Meg/<0 Alyson Oil/+8 Evil Arm/+1 Rear Sprocket
'07 Acura TL-S
'87 Buick Grand National
epd345
posted May 10, 2012 02:47 PM
I thought I read here the 14r makes more power with the stock filter in and less with it out. So why bother with an aftermarket.
CraZX14
posted May 10, 2012 03:50 PM
quote: I thought I read here the 14r makes more power with the stock filter in and less with it out. So why bother with an aftermarket.
That is correct. So unless someone comes up with a filter that flows better than factory, there isn't a need for an aftermarket one. Whether someone will build a better mousetrap than Kawasaki remains to be seen.
2003 L.E. Hayabusa
posted May 10, 2012 04:54 PM
K&N has something coming .. I don't know about BMC ..
TH1RT3EN
Trial And Error Control
posted May 10, 2012 06:12 PM
Pipercross also has one in the works but nothing available yet...
drewzx-14
Andrew
posted May 10, 2012 06:18 PM
Edited By: drewzx-14 on 11 May 2012 01:18
i recently ordered a K&N filter for my 09 R1. Do you guys really think that it was a waste of money? Is stock really better?
2009 Yamaha R1
mma-tv
posted May 10, 2012 10:24 PM
I suspect stock is better than no filter because of turbulence in the airbox. A aftermarket filter will settle the turbulence and flow more air than a paper filter. Us Mustang guys learned this years ago trying to run no filter and confusing the mass air meter with turbulence, then finding on the higher horsepower cars (500+) that a filter 'straightens' the air and increases velocity at the inlet over no filter at all.
| Quick Reply: |
