Area P
BIKELAND > FORUMS > ZX-14.com > Thread: 07 vs. 08 Crankshaft?? NEW TOPIC NEW POLL POST REPLY
posted November 06, 2009 03:03 PM        Edited By: Shane661 on 6 Nov 2009 22:04
It is my understanding that the gear on both the crank and the clutch basket are different on the 07 vs. 08. Does this mean that you can swap an 08 and 07 crank, as long as you have the matching clutch basket?
Anyone know if there are any other differences?
kawasakijockey
posted November 06, 2009 03:52 PM
Yep. They are different.
posted November 06, 2009 03:56 PM        Edited By: Shane661 on 6 Nov 2009 22:57
I know they are different....but is that all you need to change...the crank and the basket gear?
LOCK 2121
posted November 06, 2009 04:48 PM
What is diffrent, and why the change??
kawasakijockey
posted November 06, 2009 05:38 PM
The gears on the two are not the same as the 08 and from what somebody posted on Pyschobike( I think) that was the only diff. I would assume the oil pump gear would be different and also the balancer shaft gear. Not 100% sure though and I cant find that info anywhere yet.
LAB3
posted November 06, 2009 06:45 PM
Looking for the clutch basket with the largest drive gear?
2007 Metallic Black ZX-14 , Muzzy M14, Muzzy Advancer , PCIII USB ,Flys Out, TRE , Speedo Healer ,17/43, Polished Rims , Smoked Shield, Buell Pegs, LSL Riser Kit
The great OZ has spoken ..
posted November 06, 2009 07:06 PM        Edited By: smokinZX14 on 7 Nov 2009 02:21
All the gears are the same size ... The 06 07 has two ring gears , one made soild to the basket and the other loaded with spings ..What this does is load the gears and stop any basket or clutch rattle ... The 08 09 has one ring gear and uses a different cut in the basket gear and crank gear to stop basket rattle ..
I never herd of a 06 or 07 clutch with basket problems , so i wonder why Kawi made the change for 08 09 .... Cost maybe ?
09 zx14 8.76 @ 154 all motor
kawasakijockey
posted November 06, 2009 07:39 PM
One guy in Houston blew his basket up on the street last month. It was the only case I ever heard of so far.
posted November 06, 2009 07:41 PM
My reason for asking is that I sometimes see 08 cranks for sale. I was just wondering what it would take to fit one to an 07 motor; I'm still not quite clear on that.
posted November 06, 2009 07:44 PM
Shane call Jay at APE ... If he doesn't know nobody will ..
posted November 06, 2009 10:01 PM
bob carpenter, adams, cooper all come to mind
posted November 06, 2009 10:11 PM        Edited By: dubious on 7 Nov 2009 05:11
I will know when I tear evilsports zx14 down for new pistons in the next week or so probably.
I will compare his 08 with my 06
osr
posted November 06, 2009 10:58 PM
split gear ont eh clutch-- pretty sure the only thing you have to change is the clutch basket wit the crank-- not sure why you sould see the 08 cranks for sale-- havent' heard of any problems and I don't know if one is better than the other--
posted November 07, 2009 09:46 AM
would the solid gear be stronger than the split gear?(even just a little)
07 MDP Rookie of the Year
01 ZX-12R street/drag bike
8.97@ 155.7 NA (pump gas)
top speed in the 1/4: 161 MPH N2O
Quick Reply:
Copyright 2000-2010 Bikeland Media Inc.
0.478950977325 seconds processing time
