Yamaha R6 Forum
BIKELAND > FORUMS > ZX-14.com > Thread: Suzuki K5 engine wont run on 4 cylinders NEW TOPIC NEW POLL POST REPLY
johnbull
posted November 03, 2009 02:32 PM
Guys,
I've just installed a Suzuki K5 motor into a racing car cannot seem to get the engine to run on 4 cylinders.
The number 1 cylinder just wets the plug and tries to fire here and there as though the spark is sparking at the wrong time.
The injectors are all spraying plus there definately is a spark.
Could it be anything to do with a safety feature in the ECU like a limp mode or something that needs resetting????
Any ideas?
Cheers,
Josh.
John Bul Racing. Malta.
kawasakijockey
posted November 03, 2009 03:06 PM
You might check to make sure you didnt cross two coil wires.
INTIMIDA2OR
RED rider!
posted November 03, 2009 03:13 PM
Did you change the spark plug ? Could be a dud.
'06 Passion Red ZX-14 ressurected....
myspace.com/ocriderz.com
cb1100f.net
*Lee*
   Ignore this member    Click here to visit INTIMIDA2OR's homepage.
johnbull
posted November 04, 2009 07:50 AM
Coil wires are fine and pluga are all new.
Have tried swapping injectors round, coils round, just about everything and the problem remains on cylinder #1. The compression is exactly the same on all 4 cylinders to.
The spark is there on cylinder #1 but it makes me think that it is sparking at the wrong time. Is there anyway that cylinder #1 could have lost its ignition timing????
Could it be that the ecu needs re-setting with the diagnostic tool to remove any errors maybe it is stuck in limp mode??
INTIMIDA2OR
RED rider!
posted November 04, 2009 10:23 AM
Limp mode would not let you rev up high at all . Basically you give the engine throttle and nothing much happens.
What is happening to you is one cylinder is dead. I had that happen on a car once. Swapped everything and nothing was gained to make that cylinder fire.
But the cylinder had everything it needed, fuel ,spark,compression still nothing.
Did a tune up and the problem was gone!
I think even though It had spark it was weak enough to get blown out by the compression.
Geez I hate when this kind of stuff happens lol!
cb1100f.net
*Lee*
BobC
posted November 04, 2009 10:49 AM
It needs compression, a big fat spark at the right time and some fuel. Looks like you checked everything but you didn't say if the plug was getting wet.
Blue ZZR1400
Stock wheelbase
Max: 205.4 mph
Quarter: in the nines - geared 17/40
06redzx14
posted November 04, 2009 11:18 AM
check throttle bodies
Obba
posted November 04, 2009 02:51 PM
As 06redzx14 says it might be around that area.
I'm sure you know what you are doing, but i always go back to basics when i get problems like this.
I typed in '1 cylinder not firing' in google and it came up with a fair amount of stuff - from dicky DSI's, leaking vacume hoses to carbys (well, throttle bodies).
There might be something that might give you an idea.
Weird one really: If theres fuel, air, compression and a spark - it's gotta go!
Are you sure there is a spark when the plug is in, as in nothing grounding when it's all plugged in?
If the plug is wet, then fuel is getting through. If it was firing when it shoud'nt you'd certainly hear it!
An inductor timing light, with the clamp as close to the plug as possible would at least tell you that a spark, is getting as far as that.
Sorry for pointing out the bleedin obvious, just all i can think of now.
johnbull
posted November 04, 2009 03:39 PM
Thanks for your input guys.
Yes the plug is getting wet and you can tell that there is loads of unburnt fuel coming from the exhaust smell.
As Bob C mentioned, one of the things you need is the spark at the RIGHT time. You can hear the cylinder trying to fire here and there but thats it. The exhaust on that cylinder just gets warmish whereas the other 3 get red hot after a minute or so. Is there any possible way that the timing on Cylinder #1 could have got very retarted from the ecu?? would limp mode do anything like this??
Appreciate your input.
INTIMIDA2OR
RED rider!
posted November 04, 2009 09:26 PM
Does it clear up at all or does it miss all the time?
cb1100f.net
*Lee*
johnbull
posted November 05, 2009 01:17 AM
Nop, the cylinder #1 doesnt fire at all. Just pops here and there.
BobC
posted November 05, 2009 03:02 AM        Edited By: BobC on 5 Nov 2009 10:04
Have you investigated whether there's a vacuum leak on the inlet side of that cylinder?
Blue ZZR1400
Stock wheelbase
Max: 205.4 mph
johnbull
posted November 05, 2009 06:04 AM
Yep. everything is ok with the vacuum hoses etc. Since the engine was bought from a breaker, I am becoming and more convinced that someone has once tried messing around with the ecu and somehow retarded the timing on cylinder #1. My next step is to check each cylinders timing with a strobe light. This should definately indicate whether the #1 timing is out correct?? Even had the head off yesterday to see that everything is ok and all is fine.
I have read alot about people being able to access all the parameters in these ecu's (ignition tables, fuel maps, rev limits etc.), this is why I am nearly positive that it is something to do with the ecu's ignition map for cylinder #1.
BIGZXDADDY
posted November 05, 2009 11:11 AM
suck, squeeze, bang, blow is what needs to happen in that order. you checked the squeeze w/ the compression test but did you check the suck? compression doesn't always mean that the cylinder can pull in an air charge. a quick check w/ a vaccum guage will tell you if she sucks
"never drive faster than you can see, besides it's all in the reflexes"
INTIMIDA2OR
RED rider!
posted November 05, 2009 02:15 PM
Can you try a different ecu?
cb1100f.net
*Lee*
johnbull
posted November 06, 2009 01:32 AM
Tried the timing yesterday with a strobe light on all four cylinders and its fine.
INTIMIDA2OR
RED rider!
posted November 06, 2009 01:44 AM
The problem has to be something simple. Try spraying starting fluid in that throttle body while the engine is running and see if it fires.
cb1100f.net
*Lee*
BobC
posted November 06, 2009 02:29 AM
Good suggestion, I was reading about the "Propane Test" where some gas from a propane torch is sprayed around the intake, if the cylinder fires up it indicates an air leak.
Blue ZZR1400
Stock wheelbase
Max: 205.4 mph
Quick Reply:
Copyright 2000-2010 Bikeland Media Inc.
0.144477128983 seconds processing time
