Kawasaki H2 Ninja Forum
BIKELAND > FORUMS > H2 NINJA.com > Thread: H2 and H2r use same head gasket but different cams. NEW TOPIC NEW POLL POST REPLY
zx12mark
posted July 26, 2015 02:31 PM        Edited By: zx12mark on 26 Jul 2015 21:38
h2 cams 325 each .......h2r cams 500 each... h2 ecu 1001.24...h2r ecu 1500.00 ......from Ron Ayers
posted July 26, 2015 09:47 PM
I thot you would need proof of ownership to order h2r parts
posted July 26, 2015 11:16 PM
good find, mark! swft... anyone can buy any part, no? maybe it's time for a few other certain members here to tell us what other bits are needed to juice up the engine. they would know exactly which bits are different.
zx12mark
posted July 27, 2015 12:21 AM
Yes sir on what you said.Also the gas tank is 1600 bucks
posted July 27, 2015 08:00 PM
http://www.kawasaki.com/Products/2015-Ninja-H2R
2015 NINJA H2™R VEHICLE ACKNOWLEDGEMENT
VEHICLE
The Ninja H2R is a closed course riding use only model and is not manufactured for use on public roads, streets or highways. All usage of this vehicle should be limited to riding on a closed course.
PARTS
Parts designed specifically for the H2R are for closed course riding use only and cannot be purchased without proof of H2R ownership (product registration, VIN confirmation, etc.).
EXHAUST SOUND
The exhaust sound level of the H2R at the time of factory shipment is 120 dB/A using Auto Cycle Union (ACU) guidelines. It is the owner’s responsibility to confirm that noise regulations of closed courses permit vehicles reaching this level of exhaust sound. Changes to the exhaust system may alter performance and sound level.
USAGE, MAINTENANCE AND WARRANTY
As a closed course riding use only model, specific procedures must be followed when riding and maintaining the H2R:
VEHICLE TIRES:
The standard tires are designed exclusively for use on a closed course. These specialty tires are not designed for oval or partial oval course use and may not be suitable for other courses or conditions. Kawasaki recommends that you follow the tire manufacturer's instructions and warnings, and that you consult the tire manufacturer to select the appropriate tires for the course or riding conditions.
Computer controlled systems such as KIBS, KTRC, etc. are tuned with the standard tires. Use of tires other than the standard tires could affect performance of these systems.
STANDARD TIRES:
Front: Bridgestone, Racing Battlax V01F Soft
Rear: Bridgestone, Racing Battlax V01R Medium
TIRE WARMERS:
To prevent loss of tire grip, always use tire warmers to heat tires prior to riding the H2R. Cold tires do not provide sufficient grip and may cause loss of vehicle control and/or a crash which could result in injury or death.
VEHICLE STORAGE:
When storing the H2R, always use front and rear motorcycle stands that keep both tires off the ground. This will prevent tire deformation and adverse impacts on performance.
VEHICLE MAINTENANCE:
In addition to regular periodic maintenance, service inspections are required every 15 hours of engine operation above 8,000r/min (rpm). These service intervals are monitored through the vehicle’s ECU with service messages displayed on the multifunction meter. (See Owner’s Manual for additional information)
VEHICLE WARRANTY:
The H2R is sold “as-is” with no warranties, express or implied. The purchaser accepts all responsibilities concerning cost of service, maintenance and repairs.
0.27502393722534 seconds processing time
