Kawasaki H2 Ninja Forum
BIKELAND > FORUMS > H2 NINJA.com > Thread: Some New Dyno Results NEW TOPIC NEW POLL POST REPLY
RidgeRacer
posted February 18, 2015 10:12 PM
Don Guhl was at Adam's Performance earlier this week doing some ECU tuning on Gadson's bike. This bike is a hybrid. The only difference between the three runs is the ECU flash.
First some facts about Gadson's bike. It is reportedly an H2R motor (cams) with an H2R pipe but with an H2 snorkel and air filter. The runs were done with the air filter removed which added somewhere between 10-20 hp.
The code in Gadson's ECU is some kind of one off pre-production version and is likely not what will be in the delivered H2Rs. Don purchased a replacement H2 ECU over the counter from Kawasaki parts. All the Power Commander equipment was removed before the runs.
The first blue run was running the stock H2 bin with o2, PAIR and other items missing on Gadson's bike disabled. You can see the factory power restriction coming in at 10,500. Peak power was 237.9hp
The red run is the original bin as delivered with Gadson's bike except the rev limit was raised to 14,800. Peak power was 277hp
The green run is Gadson's bin with a custom fuel, ignition, and throttle maps. It peaked at 301.23 with a 40hp increase @14,500
These are all rear wheel power numbers.
We also tested a power mode patch I wrote. The stock H2 has only 2 power modes, Normal and Rain. The ECU however actually has Three sets of Fuel, Ignition, and Throttle maps; Normal, Rain and Unused. My patch makes the third set available so you can have Normal, Rain, and High Power. The mode is tied to the KTRC setting. The least intrusive KTRC 1, 2 and Off use the High Power, KTRC 3 uses Normal Power while Rain is still Rain.
posted February 19, 2015 08:02 AM
That's a few ponies
frEEk
posted February 19, 2015 10:47 AM
10-20 seems like alot of power gain just for removing the filter.
Can always count on you for fascinating posts RR.
RidgeRacer
posted February 19, 2015 01:55 PM
Check out the difference between the H2 and H2R air intake assemblies.
The H2 has a smaller pleated paper element while the H2R has a much larger area foam type element. The actual air plenums appear to be of similar sizes.
zx12mark
posted February 19, 2015 05:21 PM
Ridge it is awsum you are involved already.Do you predict we can get close to the h2r power with aftermarket within a year from now.Go for dude.
posted February 20, 2015 06:33 AM
Glad to see the news Ridgeracer!
I can see a demand not only for software, but potential retrofit items for H2 owners.
RidgeRacer
posted February 20, 2015 01:38 PM
One of those carbon fiber guys from back in the early zx-12 days needs to step up. Only problem is limited production, can you sell enough items to overcome development costs. Same thing applies to things like supercharger gearing or aftermarket impellers.
supra5677
posted February 21, 2015 09:14 PM
Greetings Ridge Racer. What did you have in mind?
Supra
posted February 23, 2015 01:47 PM
Can't speak for RR, but I would be interested in a repro of the H2R air intake. Mostly for the symetrical look of it.
RidgeRacer
posted February 26, 2015 08:41 AM
For those looking for H2R like power out of their H2 I think the issue is a little more than just cosmetic
0.22452998161316 seconds processing time
