BMW
BIKELAND > FORUMS > S 1000RR > Thread: MODDED ZX14 vs BMW 1000RR NEW TOPIC NEW POLL POST REPLY
jetskidave
posted May 29, 2010 11:43 PM        Edited By: jetskidave on 30 May 2010 15:57
Ok guys. My 2008 ZX14 has the following:
Racing exhaust
PCIII w/Custom map
Flies out
4 Degee timing advanced.
Stock air filter
Velocity Stacks
17/43 sprockets
150 LB rider
My last dyno at Steadman's Motorsports was 187/109. 5/2010.
BMW 100RR STOCK 170 lb rider
2nd gear roll on the 14 jumps out 3-4 bikes, once the BMW goes by 10,000 rpm,
it is pretty much over and he makes up the 4 bikes and easily pulls by me at the
top of 4th gear. 5-6 bikes....e-a-s-y-
3rd gear roll on, 14 jumps out again, the BMW just needs time to gain revs to get
in the power band and comes on by my 14.
It is just a fact. If you give the BMW a chance to get past 10,000 rpm when racing
a roll on your pretty much done.
You guys can bitch and moan if you want, That bike is FAST AS HELL.....STOCK!
2014 ZX14R Flat Black
Akrapovic 4 into 1 exhaust CNC Performance high performance street motor stock bore 14 to 1 CP pistons
CNC ported head, Cams, 48mm Bored throttle bodies, complete blueprinted engine,
10 Over Adams arm, GPR stabilizer, air shifter, quickshifter Guhl reflash ECU with duel maps installed in the ECU.
243hp, 302 hp on Nitrous progessive controller. BST carbon rims
  Ignore this member    Click here to visit jetskidave's homepage.
smokehouse4444
XX to ZX
posted May 30, 2010 12:05 AM
Hmmm...I don't have a problem with it at all. That Beemer is tweeked out and smokin' big time. I think Kawi and Suzi were perfectly content to just let the 14 and 'busa be essentially equal, and let all the minions squabble about who is best. I hope both companies are upset about it and throw down soon!
2008 Atomic Silver ZX-14, Brock's this and that, some other stuff, 260 in full gear, powered by Cheese
2005 Ducati 999 with all the goodies
posted May 30, 2010 12:06 AM
Stock gearing on the 14?
biggmoinc
posted May 30, 2010 12:10 AM
at 150lb n ur bike has 187hp wit 108 ft/lbs n the bike goes by u that easily, ur bike sucks, sike, just playin, but something dont seem right, as far as ur zx12r wheel, did it just bolt on? N are the 12r n 6r wheels lighter than the stock 14 wheels,
biggmo@aol.com
masszx14
A mind beside itself!
posted May 30, 2010 12:11 AM
Are you at stock gearing on the 14?
universal@mind
masszx14
posted May 30, 2010 12:12 AM
Where was I?
universal@mind
biggmoinc
posted May 30, 2010 12:13 AM        Edited By: biggmoinc on 30 May 2010 15:15
Now that i look at ur first post again, ur bike does suck!!!!!!!!!!!!! N like shane is sayin, if ur 14 is geared lower than stock then of course he going to go by u in the higher speeds, at 150lbs i would think not to many would go by u period in a rollon, little fella, lol, Also maybe if u lose that stock filter he might not pass u, ;-)
biggmo@aol.com
1badzx12r
posted May 30, 2010 12:17 AM        Edited By: 1badzx12r on 30 May 2010 15:18
x2
the thing on the right called a throttle you need to twist it open fully
posted May 30, 2010 12:19 AM        Edited By: Shane661 on 30 May 2010 15:20
Also, btw, that is not the only 1000 that will pass a 14 running on stock gearing. The bikes are light and they spin up very fast. The 14 is very heavy (well, most are).
posted May 30, 2010 12:23 AM        Edited By: smokinZX14 on 30 May 2010 15:36
I believe it ... I said before that it would win in a roll on race once it got into it power band .. But the last time i looked roll on racing isn't a class at any drag strip ...
Now guys if you what to jump ship and get a BMW fine please do so .. It a great liter bike with a double ton of hp and light weight trick parts ..
Now if you want to blow the body work off that BMW with your zx14 all you need to do is spend a little bit of cash ...375.00 bucks mill your head and clean up the bowls , deg your cams 104 106 and see a gain of 13 HP at peak and 15 HP at the limiter ..
oilfieldtrash
Kawasaki enthusiast
posted May 30, 2010 12:40 AM
Where do you get that done? 15 extra horses sounds fun.
'07 white S.E. ZX-14 sold
posted May 30, 2010 12:47 AM
Either Jim or my friend Matt ..Matt Hilton is around 350.00 and Jim is 375.00 ..
jetskidave
posted May 30, 2010 12:56 AM
I am sorry, I had just changed to a 17 front with a 43 rear sprocket.
My BAD INFO!
The zx12r wheel was direct bolt on. no problems. yes it is lighter.
Smoking14 I think knows who owns the BMW....his name is Chip, lives in middle Tennessee.
You know him?
jetskidave
posted May 30, 2010 01:02 AM
1badzx12r, you are more than welcome to come and run with us if you are close by.
See it for yourself.
My bike had not been beat up untill that day with a similar set up. no Turbo, No Nitrous.
posted May 30, 2010 01:04 AM
Hopefully the BMW's will start showing up around here! They sure sound fast!
Red1
posted May 30, 2010 02:22 AM        Edited By: Red1 on 30 May 2010 17:23
Smokin,
Where are Jim and Matt located? What is there contact information? $375 sounds like a great price to me...if they aren't too far away.
Thanks,
Red1
Red12/Blue14
gilberjj
Friend of Fast
posted May 30, 2010 03:06 AM
http://competitioncnc.com/
This is Jim's shop. He's a site sponsor and a great guy. I yakked his ear off for 30 minutes last week and he was happy to answer any and all questions. Just know that you'll be increasing compression to about 13.25:1. You'll need to be more careful about the fuel you put in your bike.
posted May 30, 2010 03:18 AM
Fter getting the headwork done, is it necessary to get it remapped? I would assume so, but asking the guys that have already done it?
oilfieldtrash
Kawasaki enthusiast
posted May 30, 2010 03:58 AM
How much would it cost for a shop to take the heads off? And gilberjj do you mean you have to run 93 octane all the time?
gilberjj
Friend of Fast
posted May 30, 2010 04:06 AM
Yes. As your compression increases, your bike will demand both higher quality and octane fuel. That being said, 13.25:1 really isn't that high. You would be fine with 93 pump.
1badzx12r
posted May 30, 2010 04:49 AM        Edited By: 1badzx12r on 30 May 2010 19:50
yada yada yada .. i can't help it your junk is slow ..and you play by the rules..
2 kinds of racers cheaters and loser's
posted May 30, 2010 07:20 AM
We used the same map for jesses bike for the dyno runs .. The a/f looked great ..Only change we made was from 87 pump gas to 93 pump gas ..
posted May 30, 2010 01:12 PM
Racing exhaust
PCIII w/Custom map
Flies out
Stock air filter
Velocity Stacks
17/43 sprockets
150 LB rider
Wheelie
Old Man
posted May 30, 2010 01:38 PM
Racing exhaust
PCIII w/Custom map
Flies out
Stock air filter
Velocity Stacks
17/43 sprockets
150 LB rider
is the Beemer rider your buddy? swap bikes and race, if he beats you again, well
wee
kaw now
posted May 30, 2010 02:09 PM
Smokin I like the extra hp also you say mill the head how much? Clean up the bowls? You mean some porting or deburring the ports? Sorry can't give you any biz unless by mail but curious how this would work out for street riding.
All times are America/Va [ This thread is 6 pages long: 1  2  3  4  5  6     Next» ] < Previous Thread     Next Thread >
0.49805212020874 seconds processing time
