Thread: AMA Test n Tune @ Fontana... PIX |
posted February 11, 2007 12:29 AM
Uploaded to the Gallery!
http://www.bikeland.org/gallery2/main.php?g2_view=core.ShowItem&g2_itemId=2874
bovinespongiformencephalo
variant Kreutzfeldt-Jakob
posted February 11, 2007 11:57 AM
Nice. Thank you.
posted February 11, 2007 02:42 PM
zxhoya
posted February 11, 2007 03:21 PM
Jamiie looks good in green.
1 question on AMA superbike configuration this year. Has there been a rule change as far as stock exhaust set-up goes? I see single sided exhaust on the GSXR and ZX. -
''The angle of my dangle is inversely proportional to the heat of my meat'' Will Ferrell
Tool man
posted February 11, 2007 11:18 PM
Hey.. Nicky was there, checking up on little brother.
The banks are failing..
The banks are failing...
Invest in Ammo
k bryant
Sponsor
posted February 12, 2007 10:04 AM
There is no rule. You can do whatever design you want. The only rule is sound based.
zxhoya
posted February 12, 2007 04:07 PM
Thanks KB. I guess sound based is max db's?
k bryant
Sponsor
posted February 12, 2007 07:56 PM
No problem. Actually the test is kinda silly. It's a SAEJ1287 based test (basically a static test, 20", 45 degree @ xx percentage of max rpm). Bottom line is that it can't be louder than 105 dbA. In many cases, that would be quieter than many aftermarket "street" exhaust systems based on those perameters. There are so many ways to get around the test and/or sound levels that it's not even funny. But then again, if you are in the pits and listen to some of the exhaust notes it can be surprising. A lot of the spectator bikes are louder than the racebikes! The Honda's are actually fairly quiet. Whereas the Ducati's last year weren't even close to 105....
posted February 13, 2007 01:09 AM
The new ducs don't bark (quack?) like the 999R.
