BIKELAND > FORUMS > CLASSIFIEDS > Thread: 06 ZX-14 Built engine for sale NEW TOPIC POST REPLY
Big_T112
posted December 29, 2009 12:29 PM
This is a turbo engine built with less that 1000 miles put on it. Good numbers, Engine is complete with shorter Carrillo rods and JE turbo pistons. 9.5:1 Comp. Stock head with H.D. valve springs, R&D race cut transmission, H.D. studs used on motor. Motor will not come with the lockup or quick acess cover but will have the clutch in it, or the Adams oil pan. Otherwise complete. $2000 You can change the pistons out and get the compression back for normally Asp. taylortim@bellsouth.net
0.23878884315491 seconds processing time
