BIKELAND > FORUMS > CLASSIFIEDS > Thread: For Sale: 2000 Kawasaki ZX12r NEW TOPIC POST REPLY
Y2KZX12R
CompetitionCNC.com
posted October 20, 2009 05:24 AM        Edited By: Y2KZX12R on 20 Oct 2009 14:47
Street Driven
Stock Wheel Base
Certified Top Speed of 218.9 MPH by the ECTA # 9326 at Loring Maine 8/2/09
220+ HP On Shell V-Power 92 (R+M/2) Pump Gas
Even More Power On VP's MRX-01 Fuel
This bike is FUN FUN on the street
This is the only year of the un-restricted zx12r with a 220mph/350kmh speedometer
The engine has break in time, dyno tuning time, 180 street miles, six 200+ mph runs
at Loring Maine and then another 285 street miles since this fresh build.
Turn key LSR bike. Doug Meyer making a pass on it at Loring 09
Dyno graph of the bike on Shell 92 pump fuel vs. an 08 piped busa and an 06 piped zx14, same dyno.
1427cc 13.44 to 1 CR
Muzzys Windowed Billet Block, 87mm Offset Bores
JE 3 Ring Pistons with Tool Steel Pins
60mm Stroke Crank by Marine Crankshaft
Carrillo H Beam Rods
Counter Balancer Removed
New Shift Forks
Muzzy Billet Clutch Basket
Muzzy Clutch Kit
BMC Race Air Filters
Reworked Throttle Bodies w/ Thinned Shafts, Blended Stacks and Manifolds
Competition CNC's Stage 2 CNC Porting
Competition CNC's custom Valve Job
APE Bronze Custom Seats
APE Bronze Guides
Kibblewhite 1mm O/S Valves
APE Springs
APE Titanium Retainers
28mm Busa Buckets
Custom Megacycle Cams .443"/257 Intake .415”/252 Exhaust
APE Adjustable Cam Sprockets
Yoshimura Duplex Race Street Pipe 4-2-1 (stainless/wrapped, with o2 Bung)
LP Ti Pipe Hangar
Walbro Fuel Pump
Bosch 430cc injectors
Power Commander PC-IIIr
24vdc Starting System
Heli Bar Risers
Muzzy Steering Damper
Muzzy Lowering Links
Front End Strap
FBG Ignition Kill Tether Switch
Billet Slash Cut Foot Pegs
EBC HH Brake Pads
Braided Brake Lines
New Michelin Pilot Sport HPX Tires
New EK ZZZ 530 Chain
Bike Is Safety Wired to ECTA Rules
OPTIONAL STUFF
Programmable Factory ECU with Selectable A&B Map Choices of the Following Tables
Individual Cylinder Fuel Tables
Individual Cylinder Ignition Advance Tables
RPM Limit of Both the Injectors and the Coils with Both Soft and Hard Rev Limits
(rev limiter is currently at 12,691 rpm)
Individual Volumetric Efficiency Tables
Individual Target AFR
Injector and Fuel Pump Supply Voltage Offset Table
LM1 Data Logger Complete Set Up Pre-Wired Into Bike to Record:
Air Fuel Ratio
RPM
TPS
Air Box Pressure (ram air)
Spare Analog Input
Spare Analog Input
OPTIONAL SPARE PARTS
Stock Block
Stock Pistons
Stock Rods
Stock Head
Throttle Bodies
Stock Cams with Adjustable Sprockets
Stock Exhaust System
Stock Bars
Stock Instrument Panel
Stock Radiator w/ Muzzy Fan
Sprockets
And More....
Over $18,000 invested, Will Sell for $9,000 or Possible Trade for ZX14
You wont find a faster street Kawasaki anywhere without a turbo or nitrous
Y2KZX12R
CompetitionCNC.com
ZRXDean
posted October 20, 2009 06:09 AM
OMG Jim that is crazy cheap! I will spread the word, but I don't think it will be around long. -Dean
oldkawboy
posted October 20, 2009 09:44 AM
Somebody will be getting the deal of the decade!
Jim........you might mention it has only been ridden by a little old man on Sunday's. :-)
Dan
brendasue555
posted October 20, 2009 02:33 PM
i WANT THIS BIKE SOOOOOOOOOOOOOOOOO BAD!
Brenda
posted October 20, 2009 09:57 PM
Dan
Doug Meyer ain't little, and he ain't THAT old, but he did have a good ride on Sun Aug 2
Awesome bike, built with the best, by the best
Y2KZX12R
CompetitionCNC.com
posted October 21, 2009 03:39 AM
Compared to you Karl, I dunno, Dan might be right with the size thing.
Y2KZX12R
CompetitionCNC.com
gilberjj
Friend of Fast
posted October 21, 2009 03:17 PM
Where are you located?
Y2KZX12R
CompetitionCNC.com
posted October 22, 2009 02:52 AM
Connecticut, Waterbury
Y2KZX12R
CompetitionCNC.com
WARBIRD
posted October 22, 2009 05:20 PM
Jim, I will contact you tommorrow.
Charles
I'd Rather Be Roadracing.
oldkawboy
posted October 23, 2009 04:07 AM
Adding to your 12 collection Charles????? :-)
Dan
Y2KZX12R
CompetitionCNC.com
posted October 23, 2009 07:06 AM
Charles
I'm heading up to Maine to close up our cottage for the season at 1 pm today.
You can call me before I head out today... or I will be back at the shop on monday.
Y2KZX12R
CompetitionCNC.com
WARBIRD
posted October 23, 2009 07:07 AM
Dan
That sure is a nice bike Jim has. Ganna call him right now..........
posted November 27, 2009 05:38 AM
TTT
posted December 11, 2009 12:49 AM
TTT
posted December 11, 2009 10:51 AM
Jim, just curious as to where the cams are set?
bump
Bawls
re-learning to ride
posted December 11, 2009 10:58 AM
If my 14 was worth it i'd swap you. That 12 is bitchin.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
Y2KZX12R
CompetitionCNC.com
posted January 06, 2010 04:55 AM
Scott, the cams are at 106/104
A trade for a zx14 is a possability, but i'm looking to get a zx14 with the new ECU. 09 or newer...
But we will see as the winter rolls on...
Y2KZX12R
CompetitionCNC.com
madkawboy
posted January 06, 2010 06:13 AM
Jim- Sorry to thread jack but will the 09 ECU work in the 07 model and is it an improvement?
Thanks,
Zack
2007 ZX-14
Stock Wheel Base, footshifting, pump gas
5.94 @ 128 mph
1.50 60ft
Y2KZX12R
CompetitionCNC.com
posted January 06, 2010 08:23 AM
Zack, no it wont work. The connectors are different and the ecu is a different 32 bit ECU.
Frm what I've read the ECU can be re-programmed without cutting into it and buying the
$200 interface connector etc. The reprograming can be done via the ecu connectors.
Y2KZX12R
CompetitionCNC.com
madkawboy
posted January 06, 2010 02:22 PM
Jim, Thanks for the explanation.
2007 ZX-14
5.94 @ 128 mph
1.50 60ft
posted January 07, 2010 03:37 PM
thanks
bump
1badvespa1400cc
power junkie
posted January 08, 2010 08:38 AM
What's the gearing on the bike?
Just another foeteen!!!!!
Y2KZX12R
CompetitionCNC.com
posted January 08, 2010 09:07 AM
For loring? On the 219 mph run If I remember correctly (we changed a few times) was 17/44... but i'm not positive on that. I'd have to look back at the notes.
Y2KZX12R
CompetitionCNC.com
posted January 08, 2010 02:11 PM
something tells me it was 18?, i run 17/49 dragracing. top speed is 170ish something revving to 11600
posted January 20, 2010 02:48 PM
bump
0.35220813751221 seconds processing time
