BIKELAND > FORUMS > CLASSIFIEDS > Thread: ZX12 parts for sale. NEW TOPIC POST REPLY
NOS1290
posted October 05, 2009 12:38 AM
ZX12 Voltage regulator
Note: This regulator was soldered by the dealer, and as such has no connector to the stator anymore. The three wires from the stator are all the same, so there is no particular order that you solder them to.All year ZX12 Kawasakis had problems with the oil running up the wires from the stator, and shorting out the connection to the regulator. The only sure way to correct this is to solder directly to the regulator.
$35 shipped
ZX12 Oil Pan
Good shape. Drilled for safety wire. No leaks or cracks.
$50 shipped
ZX12 MAP sensor.
Easy sensor to blow up because the MAP connector is interchangable with the TPS. Plug the wrong one in and the MAP is blown. This one is good.
$15 Shipped
ZX12 Tail Light OEM
$15 shipped
All parts off 2001 ZX12
badazz12
zx12
posted January 29, 2012 11:59 AM
hey was wondering if you had any 12 parts left? you can contact me at kamgreer@yahoo...thanks
badazz12
  Ignore this member    Click here to visit badazz12's homepage.
posted January 29, 2012 01:19 PM
oct 5 2009.....
0.24460697174072 seconds processing time
