BIKELAND > FORUMS > CLASSIFIEDS > Thread: Doug Garage Sale - turbo NEW TOPIC POST REPLY
posted December 25, 2006 04:51 PM        Edited By: dougmeyer on 18 Oct 2007 18:53
2002 ZX-12 B1 Vin # 001404 TURBO BIKE
This bike is COMPLETE EXCEPT for two easily replaced major parts groups.
1. All bodywork including headlights
2. Complete front end from the steering stem out except front wheel.
History:
In 2002 Mike Corbin wanted to run a ZX-12 at Bonneville with a set of his Beetle Bags hard saddle bags attached, thereby creating "The World's Fastest Bagger".
Corbin supplied Muzzys with a new 2002 ZX-12 and paid Muzzys to build the bike.
The bike was run at Bonneville that year with me attending to it and ran 219mph on 11 pounds of boost, setting a record, putting the rider into the 200mph club, and achieving Corbin's goal, pretty much right off the trailer. After that run the Innovative electronic boost control failed, and since we had no spare and Corbin had other products to work on, the bike was withdrawn from further competition. I did the tear-down for the record cert., found the engine to be in perfect shape and reassembled it.
Corbin took the bike back to Hollister where it sat for some time. During that period, Corbin removed the bodywork and front end (complete) to build a display for his showroom. Since I had expressed a desire to purchase it at Bonneville, they offered it to me and I purchased it about a year ago. The engine is out of the frame and all connections are clearly labeled for re-assembly. There are no special mods needed to any ZX-12 front end to be fitted.
When originally built, Mike Corbin spent nearly $25,000 on this bike and this was at reduced "sponsorhip" pricing from Muzzys.
Engine description:
(I've noted some original reduced cost sponsorship figures to illustrate the quality of parts used. Retail would be approx 30% higher)
84mm small pin turbo pistons $288
Custom small pin rod bushings
2nd inlet cam (used @exhaust side)
Adjustable cam sprockets
Turbo valve springs (high press inlet) $226
Cylinder head studs/nuts
Freshly fit main and rod bearings
Turbonetics T3/T4 Hybrid Turbo $1040
Multi-stage waste gate $335
Fuel pump $572
Fuel pressure regulator $331
550 cc injectors $267
Muzzy billet velocity stacks
Stainless Turbo exhaust $335
Stainless inlet ducting $170
Billet airbox (frame) filter block-offs
Billet oil filter relocation housing
Turbo scavenge pump $203
Muzzy clutch kit incl. drilled hub, springs/plates
Electronics:
DTA ECU (incl. software) $750
Innovative Multi stage boost controller (faulty)
Boost controller solenoids
Complete DTA wiring harness $146
DTA Computer data download cable
Air temp sensor
Water temp sensor
3 bar ABS sensor $75
7mm plug wires
Data acquisition:
Racepak V300 Data Recorder
8 channel (4 digital, 4 analog) $1395
4 probe EGT Option (incl. Probes) $671
UEGO O2 Sensor $600
UEGO Data Controller $400
V300 Clutch RPM upgrade $250
V300 Air Fuel module $150
Back pressure monitor $238
Manifold presser sensor $238
All necessary software
Chassis:
Muzzy welded 3" extended swing arm $350
Braided lines
Muzzy Lowering links
Stainless swing arm lift spools
Alpha Gold chain
All wiring and plumbing is aerospace and race quality.
This bike is quite capable of running with or faster than any Turbo 12 or Hayabusa out there; 225 -250 mph. The only non stock part needed is a new electronic boost controller. (There have been several improved types of controllers made available recently.) All stock parts are included. To my knowledge, this bike was never ridden other than at Bonneville.
Price: $10,000 WILL NOT SEPARATE. Buyer pays shipping. Photos available.
J_D_W_B
E-TARD
posted December 27, 2006 07:46 PM
jbeach18@hotmail.com
email me asap pics of this bike and ill let you know.
posted December 28, 2006 06:30 AM
Done
posted December 30, 2006 05:07 AM
Done
Still waiting for my Pics. you have my e-mail address
turbopete
posted December 31, 2006 10:22 AM
Could I get some pics also?
turbopete5@sbcglobal.net
stef12rr
posted March 11, 2007 02:38 PM
Dougmeyer, my friend just bought a Busa and he's able to turn off the cluster by turning off the switch instaled by the previous old owner. He turned off the switch then went for a ride and when he turned back on the switch, the mileage did not change even though he did a couple of miles. Do you know if there is a way of knowing the real mileage of the bike other than with the cluster?
NOX
PMRA / TMRC Super Street 4022
posted March 18, 2007 07:34 PM
photos?
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
posted October 16, 2007 10:01 AM
Bump- Still available. Buy it before I get some forks make it a whole bike.......
mrsantafe
posted October 16, 2007 02:08 PM
pics please acetully@earthlink.net
2006 ZX14 gone
2004 zx10r (her race bike)
2002 ZX12 (still kicking a--)
2007 gsxr 1k (race bike)
posted October 16, 2007 07:54 PM
I really really wish I could swing this!!! someone is going to get the deal of a lifetime!!!
Mad Mike
TRNorBRN6001
posted October 17, 2007 12:04 PM
MM ya ready to go in halves? You get it In Iowa during the summer April-Sept and I'll take it in the winter Oct-March. If we get Karl and Buddy it'd only be around 2800 each.
Just kidding ya, but a super deal for someone!
TFA 200MPH CLUB MEMBER!
posted October 17, 2007 03:30 PM
posted October 17, 2007 07:31 PM
Here are a few....
ZXLNT
posted October 17, 2007 11:49 PM
Drool!!!!!
0.24916696548462 seconds processing time
