BIKELAND > FORUMS > ZX-14.com > Thread: stock crank or stroker NEW TOPIC NEW POLL POST REPLY
joseph702
posted August 05, 2012 07:18 PM
need crank for my bike and every thing all said and done is 2,000$ crank is 950 . should i go with 2mm stroker or stay stock ? i do alot of 1/8 mile and extended 6 in.
joseph702
posted August 05, 2012 07:39 PM
my set up right now is 47mm tb ss head with bowles ans stuff touched up. brocks ct .
zixxer14
Damn that was Quick
posted August 05, 2012 07:43 PM
Always upgrade when repairing if possible, I'd go for the stroker. What's the price difference?
joseph702
posted August 05, 2012 07:48 PM
not sure yet i think the crank is like 200 more and eather spacer plate or thick gasket .
SteddyTeddy
posted August 06, 2012 05:29 AM
Not sure about the SS head on a stroker. Make damn sure you clearance everything!!
joseph702
posted August 06, 2012 03:27 PM
ya i was thinking about that and how there is no base shim , leavs me to think stock . maybe trad it in next year for the 14r.
BLK ICE
posted August 06, 2012 06:43 PM        Edited By: BLK ICE on 7 Aug 2012 01:44
Do a 4 or 5mm if it will fit, and you will not need to buy a 14r next year.
(I am open to Sponsorship and Product Testing and Review. Contact BlackIce Performance at blackice_performance@yahoo.com)
MrTinch
posted August 07, 2012 07:48 AM
Could you ride a 4mm stroker on street? Or 2x2 ? Spun a bearing last week thinking bout stroking her out but i do ride on the street. What do you guys recommend
ddtinch99@gmail.com
joseph702
posted August 07, 2012 09:00 AM
ya u can ride the 4mm stroker on street and i wouldnt go any more then 2mm bore. i know wrong way had built a nasty stroker and it took a pounding and liked it.
posted August 07, 2012 09:27 AM
4mm stroker will give up 1 set of piston rings unless you have a very custom setup with smaller wrist pins. 2x2 would seem to be the hot ticket for the street. Since you need a crank and pistons for the stroker app anyway, you are just looking at a little extra for bore and plate.
aceperformance.com has done a 2x2, and it made probably a bit more power than a 14R.
joseph702
posted August 08, 2012 08:45 AM
im thinking of 4mm stroke couse i dont wana bore it out funds are very tight. id deff like to go 2x2 tho.
MrTinch
posted August 08, 2012 09:02 AM
I was thinking 4mm crank and set mtc stock bore stroker piston. Would you use stock length rods with those pistons?
ddtinch99@gmail.com
MrTinch
posted August 08, 2012 09:26 AM
ddtinch99@gmail.com
joseph702
posted August 08, 2012 02:02 PM
stock lenth rods have a better piston to rod ratio but u loose a set or set of piston rings, but on the outher hand the short rod puts stress on piston wall. i think alot of people lean with stock lenth rod. im gana say the hell with it and go 4mm stroke. if money gets better ill go 2mm bore too.
Quick Reply:
0.212172031403 seconds processing time
