BIKELAND > FORUMS > ZX-14.com > Thread: Oxygen sensor question.... NEW TOPIC NEW POLL POST REPLY
oldkawboy
posted June 26, 2012 07:00 PM
I have a Daytona Wego III and my O2 sensor crapped out. With a couple events coming up I ordered a new one thru them directly. They list for 100 bucks or so but they sold it at Racers cost, about $80 shipped.
It's a Bosch LSU 4.2 and after getting the numbers off of my old one it's a OE Volkswagon sensor but the connectors are different.
This may be old news to you guys but I was wondering if I can re-wire my old connector to a new sensor? They can be bought for 40 something bucks which would be great if it's doable.
I'm wanting to take a spare on my upcoming race trip.
Anyone done this????
Thanks,
Dan
1badzx12r
posted June 26, 2012 07:07 PM
yes i've cut old plug and wired it to a new sensor before .. in a pinch and must have that day .. work fine
http://www.youtube.com/watch?v=8rh6qqsmxNs&feature=related
oldkawboy
posted June 27, 2012 05:59 AM
Thanks Bad....
Dan
SteddyTeddy
posted June 27, 2012 06:31 AM
As long as you use your original connector you should be fine. There is a built in resistor on one of the contacts that they change for different applications.
oldkawboy
posted June 27, 2012 03:15 PM
I'll look for that Ted........thanks,
Dan
Bueller
posted June 27, 2012 03:33 PM
off topic but kinda in ballpark. If you run a wego with o2 and wanna add wideband o2 with autotune, do the work off same o2, or do you need to have another bung?
joel787
posted June 27, 2012 03:48 PM
The wideband itself has a dataloger why would you want two?
posted June 27, 2012 05:51 PM
good to know
07 MDP Rookie of the Year
01 ZX-12R 8.84 @ 156.3 no bars, DOT rubber, Pump Gas NA..... turbo 8.47 @ 164
00 ZX-12R 8.62 @ 165.2 no bars, slicks, Pump Gas, 55 shot
00 ZX-12R stock with bolt ons NA 203.694 Loring 2012
Warp 12 Racing!
Bueller
posted June 27, 2012 09:10 PM
did not see anywhere it said it also logged. thx for info.
Quick Reply:
0.205414056778 seconds processing time
