kawasakijockey
posted June 25, 2012 03:18 PM
Muzzy Stage 1 turbo
Who has one and what do you think of it? Are you using pump gas?
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
codyc_13
posted June 25, 2012 03:58 PM
DO IT!!!!
8.97 at 149mph
1badzx12r
posted June 25, 2012 03:59 PM
quote: DO IT!!!!
what he said ..
duncan
posted June 25, 2012 05:28 PM
nothing like boost!
kawasakijockey
posted June 25, 2012 05:34 PM
quote: DO IT!!!!
I just might! On the fence to do something if I decide not to buy the new 14.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
smokinstorm
Old Drag Racer
posted June 25, 2012 06:00 PM
I can only add that the 09 14 we have I believed to be the greatest bike ever produced until the turbo 14 arrived. A turbo 14 is just in a league by itself. IMO of course. You will not be sorry for purchasing turbo 14. I think we're going to end up somewhere around 350 horsepower to the tire on a stock motor.
2009 Monster Edition ZX14
It's all stock I swear. Well...almost.
2005 Turbo Busa
2001 GSXR 1000
Looking for a 1985 GS1150E
Romans
posted June 25, 2012 06:06 PM
I have both but I go for the Turbo when it's time to ride, just to dame much fun.
1badzx12r
posted June 25, 2012 06:29 PM
why not mr. turbo being local and muzzy way up north
Slow14_Fz1
posted June 25, 2012 06:36 PM
My little brother has the stage 1+ boost set at 7psi 91 pump gas with 104 black octain booster and fried a piston so bad he needs a new motor. he had a auto tune on it with the AF set at 11.8 but he (Never had it tuned) on a Dyno so if you get a turbo have it tuned ASAP by someone who knows what they're doing.
08 zx14 Turbo 17lbs 8.84@159 spinning
2012 zx14r NA 5.93@118 9.30@147 best 1.37 60'
BlackMagic14
posted June 25, 2012 06:45 PM
If you want a good deal on a very slightly used one check the classifieds
1badzx12r
posted June 25, 2012 07:42 PM
quote: 91 pump gas with 104 black octain booster and fried a piston so bad he needs a new motor.AF set at 11.8 .
.. being fuel rich don't mean detonation won't happen and running low grade fuel with an additive is just asking for it ..
smokinstorm
Old Drag Racer
posted June 25, 2012 07:57 PM
From everything I've read and heard, e85 is the way to go if you have this fuel available. Use it if you can. We're going to switch the other turbo bike over to it as soon as possible. The turbo 14 is already running it and I can assure you the previous owner knew what he was doing and settled on this fuel. Right, sir????
2005 Turbo Busa
2001 GSXR 1000
Slow14_Fz1
posted June 25, 2012 09:15 PM
Edited By: Slow14_Fz1 on 26 Jun 2012 05:26
We can only get 91 pump gas around here no e85 or we would use it I use C14 when I run on spray even on a small 30 shot so I guess he had it coming sooner or later.
We have to drive 45 miles just to get the race gas we use at the track my brother was racing a 2012 zx14r on the street and stayed in it to long without any race gas but he won lol
Anyway turbos are fun if you use good gas and have them tuned before you go out and hammer the crap out of them.
Oz Booster
posted June 25, 2012 11:38 PM
Not just the tune or gas, some kits boost creep so up in the top end of the range your getting maybe 8 or 10 psi instead of the 6 you thought you had
a check valve in the boost gauge line or logging finds it quickly but difficult to see yourself as your usually hanging on tight and looking where your going at that point
anything with an internal wastegate neds checking and some with external
Done about 15 kits before on various bikes so i'm not inexperianced and the current 14 i built has 2 psi creep , and i took the usual precautions , big hole to the wastegate, nice entry angle and ported the housing to promote flow , 2 psi is no big deal if your aware of it and know its not going to be a problem, but if you had a street bike with std compression it can be the difference between a long enjoyable turbo experiance and a short & sour one
1badzx12r
posted June 26, 2012 03:39 AM
Edited By: 1badzx12r on 26 Jun 2012 11:39
quote: We have to drive 45 miles just to get the race gas.
i us to have to drive 75 miles 1 way to get E85 .. @2.50 a gal. i'd buy 30 gallons and it would keep for the 3 months that i took to use it up .. also it was always tested for grade and same grade was used for 6 months ..most time E85 around here is a E90 to 95 but in the winter time i've seen it drop to E75 . so if you ran to a dyno without testing the grade and had the winter mix .. summer time you would be running lean..
01smokes
posted June 26, 2012 08:31 AM
E85/c16 is where it's at for a turbo bike if your gonna be wanting to make power. FUCK PUMP GAS
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
Bad in Black
posted June 26, 2012 09:05 AM
quote: Who has one and what do you think of it? Are you using pump gas?
Dave the triumph guy on here has a Muzzy stage 1 on his stock 14 with almost 40,000 trouble free touring miles on it. He just bought a 14R but is still keeping his boosted 14 because he likes it that much. Sounds to me like the muzzy kit would be a good choice for a long life turbo 14. I'm also running a boosted 14, I have the same kit as Romans........I won't mention the name because the kit maker has turned out to be less than honest anymore, plus I think the Muzzy kit is a better kit anyway from what I've heard.
I've ran my boosted 14 for 2+ seasons now on VP Street Blaze 100 octane street fuel with no issues. I never race it tho, just street riding. There's nothing like a turbo 14.....and if you don't get boost greedy, and set up the kit properly, they can last a very long time. Lots of very experienced turbo guys here for advice whenever you need it. Romans has a ton of experience with a turbo and the DJ auto-tune system if you go that route
So as Nike would say "Just do it!!"
dakota9498
posted June 26, 2012 09:15 AM
I don't have a pony in this race, but I would call Chris Jones for a street kit before I would give a dime to Muzzy.
2008 ZX14
1badzx12r
posted June 26, 2012 10:21 AM
quote: Dave the triumph guy on here has a Muzzy stage 1 on his stock 14 with almost 40,000 trouble free touring miles on it."
i think he lost 1 engine
Bad in Black
posted June 26, 2012 10:26 AM
I musta missed that, you know what happened big guy?
01smokes
posted June 26, 2012 10:42 AM
I think he lost a pump
01smokes
posted June 26, 2012 10:44 AM
But if you are smart about a turbo kit and piece one together you can save a ton of money. Like thousands!!
kawasakijockey
posted June 26, 2012 02:27 PM
Just want 3-5 lbs of boost to be truthful.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
izmuk
09 no flies,pvc,muzzy,low.long
posted June 26, 2012 03:00 PM
is it possible to run a stage 1 kit on a stock motor and on pump gas have it tuned correctly and not fry yout motor. after reading this and other turbo threads it seems like sooner or later you will melt something?????
1badzx12r
posted June 26, 2012 03:15 PM
quote: Just want 3-5 lbs of boost to be truthful.
http://www.ebay.com/itm/Electric-TURBO-TURBOCHARGER-KIT-3-PSI-900-Watt-Cold-Air-Intake-fits-Hyundai-Kia-/300732376081?hash=item46050be411&item=300732376081&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr
