BIKELAND > FORUMS > ZX-14.com > Thread: Greetings from Greece NEW TOPIC NEW POLL POST REPLY
lazarosp
posted June 24, 2012 08:04 AM
Hello everyone, I am Lazaros from Greece and I own a 07' ZX14 with the following mods:
full exhaust 4 into 1 TiForce
DNA air filter
power commander III with ignition module and quick shifter
g-pack over 3
wiseco pistons
muzzys camshafts, cam sprockets and valve springs
ported head
46mm throttle bodies
higher volume gas pump
removed counterbalancers
high volume oil pump gear
muzzys radiator fan
I never drag raced it yet but the previous owner did and made 1/4m 9,2sec.
Here are some dynos all of them on a Dynojet 200i
Happy to be here
lazarosp
posted July 14, 2012 04:20 AM
Can someone help me about gearing?
I am running at stock length and 17-43 gearing.
As you can see frome the all gear dyno pull my bike runs 220 mph (the dyno was made with a almost wear out tire and 17-41 gearing)
With the 17-43 gearing I run 215 mph (on dyno)
I have the rev extented to 11.900rpm and the power comes at high rpm.
I weight 200lbs. What yould be the best gearing for doing roll ons and drag?
I don't rev to 11.900rpm, I usually rev to 11.500rpm and have the rest 400rpm for not hitting the limiter!
posted July 14, 2012 09:24 AM
First off welcome .. Looks like the bike makes great power .. As for gearing you will just have to try some different gears till you find what works for you .. No one gear works for everyone .. Riding styles and weights all come in to play .... ..
0.21023797988892 seconds processing time
