BIKELAND > FORUMS > ZX-14.com > Thread: Is it ok to mix engine ice and water NEW TOPIC NEW POLL POST REPLY
BlackMagic14
posted June 23, 2012 03:46 PM
I think I got
My
Cooling system fixed up today. I got a new hose to replace the one with the hole and installed the second fan which by the way is a bitch when the up pipe to the turbo is where the fan should be. We had to do some ghetto engineering lol. I ordered a zx10 fender and brackets should be here next week. Well I rode it for about 15 minutes and it seemed better now I'm back at the house at it has bled all the air to the top of the radiator so I need to add a little more coolant but I'm out of engine ice. Is it ok to put a little water in there to finish it up?
speedgene
posted June 23, 2012 04:40 PM
Yes. Distilled only. As long as you have a lubing percentage, cutting that with distilled will not effect the wear of the pump blades any more or less.
E-tard
zixxer14
Damn that was Quick
posted June 23, 2012 04:56 PM
I've done it also but didn't use distilled, more like garden hose. Hope that you get the heat under control. Looks like the only thing you haven't done is add more radiator.
smokinstorm
Old Drag Racer
posted June 23, 2012 05:58 PM
I used distilled water and mixed it 50/50. Can't say for sure it helped all that much though. The other fan from a GSXR1000 sure did though.
2009 Monster Edition ZX14
It's all stock I swear. Well...almost.
2005 Turbo Busa
2001 GSXR 1000
2003 Turbo GSXR 1000
Paul2281
posted June 23, 2012 07:17 PM
Engine Ice is pre mixed and is supposed to be used as it is in the jug...Thats whats nice about that stuff...No mixing ect.ect...If you need more you just buy another jug or thin it out with distilled water....But you`re not supposed to have to add anything to the stuff...It has ionized water in the mix....Plus it`s good in the cold weather too,won`t freeze up....If you used it 50/50, you messed up the ratio....Use it straight from the jug....I just buy 2 of them and have extra incase I need some extra sometime....
smokinstorm
Old Drag Racer
posted June 24, 2012 01:56 AM
Oops! Time to redo it.
2005 Turbo Busa
2001 GSXR 1000
Paul2281
posted June 24, 2012 06:31 AM
You would get better results if used right from the container,no adding....
Paul2281
posted June 24, 2012 11:55 AM
De-ionized water is what I meant....
Bueller
posted June 24, 2012 01:18 PM
We actually took out tstat, added muzzy blade to stock fan, 08 gsxr 1k 2nd fan, wetter water concentrate with distilled water. Bike takes 45 mins to get to 3 bars at idol with fan on, and has only hits 4 bars at end of night hot lapping and in stopped traffic on Myrtle Beach strip. On this motor setup with stock pistons and cams, has zero temp issues.
Kazairl
posted June 24, 2012 01:28 PM
Engine ice is just propylene Glycol. It works and mixes just like regular ethylene glycol. A little extra distilled water isn't going to hurt it any.
smokinstorm
Old Drag Racer
posted June 24, 2012 05:04 PM
I figured a whole lot of the improvement was the 2nd fan. That fan should have been used in the movie "The Wizard of Oz" to simulate the tornado approaching.
2005 Turbo Busa
2001 GSXR 1000
Bueller
posted June 24, 2012 05:59 PM
i know right lmao! you can feel the air through side vent 3 foot away
Quick Reply:
0.217032909393 seconds processing time
