BIKELAND > FORUMS > ZX-14.com > Thread: AIrShifter Wire Harness NEW TOPIC NEW POLL POST REPLY
Bishopzx12
posted June 19, 2012 02:33 PM
I have heard that the 2012 zx14r has what is called a positive horn vs what most bike including the gen1 zx14 had what is called a negative horn which make this part from MPS null and void(1-0335 MPS Horn/Shifter - Starter/NOS Switch Swapper). I wanted to add this harness to make the wiring of my air shifter easier and have the plug and play feature already there when I decide to ad nitrous. Can someone help me on this or is buying two of the (part number 1-0317 MPS Horn Button/Air Shifter Control Switch Swapper) my only choice.
What type of horn do we have?
1996 ZX7R
1999 ZX9R
1999 ZX11
2000 ZX12R 1270
2002 GSXR 1000 "I was Drunk"
2003 ZX12R 1375
2006 ZX14
2012 ZX14R
Viper
posted June 19, 2012 02:37 PM
I have the mps harness that comes with the kit, It has directions for whichever horn u have
2012 ZX14R SE
Bishopzx12
posted June 19, 2012 03:30 PM
Yes understand that.. But i was wondering if the combo one worked as well, they sit it will only work with a negative horn
1996 ZX7R
1999 ZX9R
1999 ZX11
2000 ZX12R 1270
2003 ZX12R 1375
2006 ZX14
2012 ZX14R
SixSixoh6
posted June 20, 2012 09:45 PM
why dont you use spade connectors on the horn...hook up the system...if it doesn't work then flip the wires. only referring to whats being applied when the switch is pressed (b+ or ground)
Quick Reply:
0.0405120849609 seconds processing time
