Thread: Has Anyone Seen This Before? [ This thread is 2 pages long: 1 2 Next» ] |
BrucerZX14
posted June 17, 2012 03:20 PM
Out racing this past weekend and the #2 cylinder quits. No strange mechanical sounds. Get it home and pull the plug. Here's what I found. There are no impact marks at all on the ground. The ground just rolled over and caused a very small gap so the ground never hit the center electrode.
Background info. Competition CNC SS head. 50 shot of nitrous on a progressive controller. Bike ran great thru the entire pass. No over-rev. Noticed the poor idle when I made the hit the return road. Has anyone seen this before?
1badzx12r
posted June 17, 2012 03:24 PM
..you got your money worth from your 50 shot and CNC head ..cause air didn't cause that
http://www.youtube.com/watch?v=8rh6qqsmxNs&feature=related
kawasakijockey
posted June 17, 2012 03:32 PM
Piston kiss or detonation..
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
BrucerZX14
Edited By: BrucerZX14 on 17 Jun 2012 22:35
1bad - That's why I'm asking. There are zero impact marks on the ground. If something came loose and hit it, there should be a mark on the ground and on the piston. Looking down thru the plug hole, there's no mark on the piston either. Gonna do a compression check and borescope the hole and see if there's an issue.
BrucerZX14
posted June 17, 2012 03:37 PM
Kawjockey - Quite possible on the detonation. There are no marks on the piston or plug from an impact. The other plugs are a light tan color. Gonna check compression and scope it. If all looks good, I'll put fresh plugs in it and see if I can get it back on a dyno.
1badzx12r
posted June 17, 2012 03:46 PM
Edited By: 1badzx12r on 17 Jun 2012 22:48
quote: . There are zero impact marks on the ground. .
i doubt you'll see any impact from that light of a tap.. but something touch it
just think when you drop a plug and close the gap it leaves no mark
1badzx12r
posted June 17, 2012 03:54 PM
hey did your track reopen
BrucerZX14
posted June 17, 2012 07:19 PM
The track has been bought and we're waiting for the new owner to open it.
1badzx12r
posted June 17, 2012 07:23 PM
quote: The track has been bought and we're waiting for the new owner to open it.
cool let us know when they have their grand opening race
BrucerZX14
posted June 17, 2012 08:32 PM
I will. Hopefully I'll have mine repaired by then.
BrucerZX14
posted July 03, 2012 06:23 PM
Edited By: BrucerZX14 on 4 Jul 2012 01:23
Well...finally got back to the bike to figure out my problem. #2 cylinder has extremely low compression. Did a leak down test and felt air coming out the exhaust port. SUCKS!!!! In the process of yankin' the head. Hope it don't cost much to fix it.
1badzx12r
posted July 03, 2012 07:52 PM
quote: Did a leak down test and felt air coming out the exhaust port.
i'm taking it you did had gap under your exhaust cam when you did this..(valve clearance)
BrucerZX14
posted July 03, 2012 08:11 PM
Edited By: BrucerZX14 on 4 Jul 2012 03:19
No. Just felt air coming out even with cams removed. Hope to have the head off tomorrow. Not much more to do to get it off.
BrucerZX14
posted July 03, 2012 08:50 PM
Just pulled the bucket/shims off all the valves and they all look the same. Even the #2 cylinder. Wondering if the seat is broke or chipped a valve. Find out tomorrow.
1badzx12r
posted July 04, 2012 05:58 AM
quote: No. Just felt air coming out even with cams removed. Hope to have the head off tomorrow. Not much more to do to get it off.
i alway check valve clearance before cam removing .. it helps to diagnose the problem
cams removed is the easiest way to leakdown .. you have either a bent valve or burnt valve . or something stuck under the valve ..
if you'd check clearance you would have a better idea... cause the valve being hung open would give you a big clearance.
if its a bent valve some how that piston jump up and hit it ..and seeing that plug bent .. i'd look at that rod bearing
joseph702
posted July 04, 2012 08:05 AM
maybe rod streach or somthing my ss sport head did same thing at 10,000 rpm , but mine ended up being from thin head gasket with ss sport head.
BrucerZX14
posted July 04, 2012 08:54 AM
Well. Broken piston. No damage to cylinder wals. Gotta pop the valves out and look at them yet. Here's the piston.
1badzx12r
posted July 04, 2012 09:18 AM
i broke 1 just like that before
06redzx14
posted July 04, 2012 10:06 AM
X2 have those injectors cleaned before you but it back together
zixxer14
Damn that was Quick
posted July 04, 2012 10:12 AM
Ouch, any idea what caused that?
BrucerZX14
posted July 04, 2012 10:34 AM
Edited By: BrucerZX14 on 4 Jul 2012 17:34
Zixxer - Suspecting detonation. Good thing is the cylinder wall wasn't damaged so it won't be too expensive to fix.
06Red - Gonna look at everything before it goes back together.
1badzx12r
posted July 04, 2012 10:52 AM
it looks like the piston next to it on the bottom of the pic has detonation also
JZX
posted July 04, 2012 11:15 AM
How are the valves in the head?
06 ZX14 65"
Best 1/8 mile 5.68@126.4 on a 1.41 60'
Best 1/4 mile 8.87@152.7 on a 1.47 60'
BrucerZX14
posted July 04, 2012 11:36 AM
They look alright as installed but haven't popped them out yet so I can look at the valve seat. Gotta get my hands on a spring compressor tomorrow and go from there.
06redzx14
posted July 04, 2012 01:19 PM
That is a lean/detonation issue. My number 1 cylinder was leaner than the rest a couple years ago. Found out the injector was bad when I sent them to be cleaned.
| Quick Reply: |
