BIKELAND > FORUMS > ZX-14.com > Thread: 14 R Aftermarket Rims. NEW TOPIC NEW POLL POST REPLY
Romans
posted June 10, 2012 04:03 PM        Edited By: Romans on 10 Jun 2012 23:59
Hey guys, any issues with wheel sensors or the KRTC when making the change over to after market Rims ? Any do or do Not's ?
2012 ZX-14 R, 2010 ZX-14 Turbo, 2007 ZX-14, 2009 ZX-6R, YZ 450F
justoyz2
Justoyz Racing
posted June 10, 2012 05:47 PM
none, it really has nothing to do with the wheel. The sensor is mounted to rear brake bracket and the front is mounted to the front fork. The rim sensor is mounted atop the brake rotor.... I have BST installed, no issues
2012 zx14R, 2011 zx10R, 2008 zx10, 2007 zx10 Turbo.....
posted June 10, 2012 05:50 PM
You got BSTs ?? wow i want at least 5 bikes and the move when we race ..
Romans
posted June 10, 2012 06:26 PM
So there was no issues with the rotor sensor frame ? Did it bolt onto the new your new brake rotors the same way ? Thanks Again. Any pics ?
Romans
posted June 10, 2012 06:38 PM
Here is the quote that is throwing me off. Sounds like OEM front rotors won't fit so maybe sensor frame wont fit onto new rotor ?
TRI-R Wheel & Rotor Package. Includes: TRI-R Wheel Set, Special CZ Works 320 Front Disc Rotors "Big Brake Kit", CZ Caliper Spacers* and Rotor Bolt Kit. * Does not apply to some models. Accepts the Stock/OEM rear rotor
justoyz2
Justoyz Racing
posted June 10, 2012 06:53 PM
Lee, you get nothing... 9 months of rust and plus I will not be shorting the bike no 1:30 short times....
Everything bolted up with no issues
darrylez1
posted June 10, 2012 07:08 PM
Rick should mount no problem ,just DON'T use red loctite
07 14 ,brock S-meg BST's,2012 14r BST's ceramic bearings,rear sets ,full Hindle Evo
Romans
posted June 11, 2012 03:08 PM
Thanks Guys. Big purchase. I would hate to have issues. Cheers.
posted June 11, 2012 04:12 PM
The Tri-R will have an issue since the wheel speed ring bolts to the hub and requires a ZX-14 bolt pattern. Tri-R use a CBR1000 pattern.
Romans
posted June 11, 2012 04:16 PM
Yikes, One would think they would not Advertise for the 2012 14 R.
Thanks Shane. Cheers
Quick Reply:
0.206881046295 seconds processing time
