Thread: PCV map switch? |
samin
posted June 09, 2012 10:39 AM
PCV map switch?
Does it works on the fly as stated at DJ´s website?
Can´t get mine to work... It´s properly connected/wired. 2 are maps loaded, so it is enabled.
Any ideas?
Thanks,
Sami N
*Who's General Failure and why's he reading my disk?
* ZX-14 ABS -08, Finnish guy ^^
Seno
BANNED FOR LIFE!
posted June 09, 2012 03:15 PM
Did you test the switch to make sure it is functioning correctly?
samin
posted June 10, 2012 10:00 AM
Yep, and also directly with a wire.
I´ll do some more testing (hopefully) tomorrow
BrucerZX14
posted June 10, 2012 12:46 PM
Edited By: BrucerZX14 on 10 Jun 2012 19:48
The switch is just an on/off switch. Hook up your PC. Bring up the PCV software. Start the bike and toggle the on/off switch. Should go between map 1 and map 2. Mine won't toggle with just the key on. Has to be running. The only way to see the map change without the bike running is to turn the ignition of the back on after toggling the switch.
vailes3705
Gettin Better
posted June 11, 2012 11:51 AM
Edited By: vailes3705 on 11 Jun 2012 18:54
Did you go into the tools menu in the PCV and turn on the Map Switch option? I had to do that on both my PCV's when I installed Map Swithces on them.
2011 ZX14, Lowered, 64", strapped, mirror block off's, Brocks AH, BMC Race filter, flies out, PCV with Brocks map, MPS Air Shifter, 16/43 gearing, Shinko U-Soft.
Best 1/8 mile to date:
5.90 @ 121
1.46 60ft
samin
posted June 11, 2012 01:20 PM
Edited By: samin on 11 Jun 2012 20:21
quote: Mine won't toggle with just the key on. Has to be running. The only way to see the map change without the bike running is to turn the ignition of the back on after toggling the switch.
Is that so? Then, problem solved. Thanks A Lot!
When I tested it while driving, I was expecting to see some changes in AFR values (have logger) but it was quick test between 2 DJ´s maps. Never tested with laptop with toggling the switch on and off. I had always power on.
| Quick Reply: |
