BIKELAND > FORUMS > ZX-14.com > Thread: Help with Seat Faring "moving" NEW TOPIC NEW POLL POST REPLY
Thread: Help with Seat Faring \"moving\"
peaveyplayer
posted May 29, 2012 07:19 AM
My seat fairing is moving around, has a little gap ( at the end) actually before I even leave. When I'm on the move, I can see it vibrating a little. Does anyone know a way to get this to stay flush with the tail tip fairing and look good? The fairing has the padding inside of it, but doesnt seem to do anything. Thank you for your help .
Wheelie
Old Man
posted May 29, 2012 07:33 AM
The seat cowl?
wee
posted May 29, 2012 07:44 AM
Most likely it's not latched down on the rear latch ...mine does that if i don't get it latched down just right ... you have to play with it sometimes to get it to latch ...
peaveyplayer
posted May 29, 2012 08:13 AM
Hers a picture to help out. I have the seat latched down. It seems like it needs a magnet or something to hold it down.
Wheelie
Old Man
posted May 29, 2012 08:21 AM
Like Smokin said. , mine does it I hit down on it with the bottom of my fist.
wee
peaveyplayer
posted May 29, 2012 11:08 AM
ive done this though, ive pushed till its hit the seat... still tryin stuff
posted May 29, 2012 01:37 PM
Yup not latched .. remove it and try again ..
Wheelie
Old Man
posted May 29, 2012 01:44 PM
I just took my seat off, it will not latch by pushing, hit it with the side of your hand just slightly.
wee
vailes3705
Gettin Better
posted May 29, 2012 02:26 PM
Mine does the same thing sometimes when it's not latched all the way. I just sit on the seat and bounce once or twice unitl I hear the latch fully engage.
2011 ZX14, Lowered, 64", strapped, mirror block off's, Brocks AH, BMC Race filter, flies out, PCV with Brocks map, MPS Air Shifter, 16/43 gearing, Shinko U-Soft.
Best 1/8 mile to date:
5.90 @ 121
1.46 60ft
MotoCycho
posted May 29, 2012 04:46 PM
Funny this has come up.. I fixed two of them yesterday.
1. On my friend's 14 I removed the back latch bracket from the seat and put a slight bend just forward of the bolt hole then bent it back a little at the angle bend it already had to get it straight again. The net result is the rectangular hole that the latch catches is sitting lower and can catch the latch rod easier.
2. On my 14 I decided to try something slightly different since mine would catch slightly easier than his did and needed less "fix". On mine I used a jewelers file to ever so slightly file the bottom edge of the rectangular hole that the latch rod catches larger.. the net result again is to move the hole down a little to make it easier for the latch to catch.
Both fixes worked!
peaveyplayer
posted May 29, 2012 07:39 PM
that does make sense, ill try that tommorrow... just got done putting on half of my new fairings.... china ones, so its been a hell of a time. ill let ya know the outcome tommorrow lol.
Quick Reply:
BIKELAND > FORUMS > ZX-14.com > Thread: Help with Seat Faring \"moving\" NEW TOPIC NEW POLL POST REPLY
0.207748889923 seconds processing time
