BIKELAND > FORUMS > ZX-14.com > Thread: Drag Race Only Application NEW TOPIC NEW POLL POST REPLY
trganey
posted May 24, 2012 09:09 AM
If you were using your bike in a drag race only application and wanted the ecu to only see one gear which one would it be. I've been told that 6th would be the best because of the way the ecu is programed to apply timing and fuel. What is your opinion?
posted May 24, 2012 09:19 AM
Is there something wrong with the way it is?
1badzx12r
posted May 24, 2012 09:53 AM
Ain't that what a TRE does
http://www.youtube.com/watch?v=8rh6qqsmxNs&feature=related
blackbullet76
posted May 24, 2012 11:23 AM
Isn't 5th and 6th the same?
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
vailes3705
Gettin Better
posted May 24, 2012 12:59 PM
Why not just use a T.R.E. ?
2011 ZX14, Lowered, 64", strapped, mirror block off's, Brocks AH, BMC Race filter, flies out, PCV with Brocks map, MPS Air Shifter, 16/43 gearing, Shinko U-Soft.
Best 1/8 mile to date:
5.90 @ 121
1.46 60ft
trganey
posted May 24, 2012 05:02 PM
If a TRE would lock the timing down and lock the fuel curve so it would not self tune against me that would be fine. Then on the other hand if there is a cheaper and more simple way to get it done without adding yet more electronics to an already cramped and overloaded total loss system then I'm for that route. In the end being more consistant and being able to slow the bike down so we can run TG is what we are after.
trganey
posted May 24, 2012 05:06 PM
I believe it would be more consistant and easier to tune if the timing and fuel were not being changed by the ecu.
Wheelie
Old Man
isn't your motor stock?
wee
trganey
posted May 24, 2012 05:07 PM
Not sure that's why I am asking the Pro's!
trganey
posted May 24, 2012 05:11 PM
wee
NO not exactly. It's a 2x4 with stock valves,cams,etc,etc. Last time out we were running from the high 7's to 8 teens and could not slow the bike down consistantly to be able to run TG. Any helpful advice is appreciated.
Wheelie
Old Man
posted May 24, 2012 05:15 PM
Your first question sounds like you want more speed, your second question you want to go slower? lol
wee
trganey
posted May 24, 2012 05:22 PM
More speed would be welcome if it were consistant. We have just completed installing a throttle stop to take care of the too fast part, now if we can get a grip on the consistency maybe we could be competitive.
Quick Reply:
0.22336101532 seconds processing time
