BIKELAND > FORUMS > ZX-14.com > Thread: PFM video clip NEW TOPIC NEW POLL POST REPLY
Bigbore4
posted May 21, 2012 09:38 PM
PFM video clip
Just a short video demonstrating the almost zero drag on this Superbike Brake system from West engineering.
http://youtu.be/togCIjIl2U0
Bigbore4
posted May 21, 2012 09:57 PM
If someone wants to assist with the link
Seno
BANNED FOR LIFE!
posted May 21, 2012 10:32 PM        Edited By: Seno on 22 May 2012 12:32
Seno
BANNED FOR LIFE!
posted May 21, 2012 10:35 PM
Looked great until I heard "2 grand for the kit". I will settle for some drag from stockers until they are worn out
riteristrob
posted May 21, 2012 10:43 PM
I like it!
Speaking of brake drag......I just installed Galfer Wave rotors and HH pads. After a 330 mile ride I checked the drag and they were so tight I could hardly spin the wheel. I have clean fluid so I know it wasn't pressure from water vapor created by the heat. I also clean the calipers really well before installing. before the ride I took a short trip through the neighborhood to make sure everything was good to go and there was hardly any drag when I got back. I plan on taking the pads out and checking them.
Any recommendations on what else I can check?
posted May 21, 2012 11:31 PM
spend the $2K or...
send both calipers to Thomas Miceli - cell 609 528 9466 who will do some lil magic mod (which retains the dust seals), and for about $50 each, poof goes the dragging.
I have used Thomas' caliper mod on my LSR zx12 and both my LSR Busas, no brake dragging whatever
Bigbore4
posted May 22, 2012 03:08 AM
The "good" guys have some tricks that make the zero drag a reality.
posted May 22, 2012 03:19 AM
spend the $2K or...
A lot cheaper than 2k!
zixxer14
Damn that was Quick
posted May 22, 2012 12:17 PM
If you're going to blow $2k on calipers you need to spend for ceramic bearings too, come on.
Bigbore4
posted May 22, 2012 12:20 PM
Not 2 grand on calipers, 2 grand for the kit. The thing rolls so easy now, I'd be afraid to put ceramics in it for fear it would just roll off on it's own
Bigbore4
posted May 22, 2012 12:21 PM
The zero drag is one thing, but the other is that these are the best friggin brakes I've ever used.
posted May 22, 2012 04:01 PM
LOLOLOLOL
BobC
posted May 22, 2012 08:45 PM        Edited By: BobC on 23 May 2012 14:15
I like it!
If you've just installed new pads it's likely that the pistons are pushed back further into the calipers displacing the fluid, have you still got an air-gap at the top of the master cylinder?. When you cleaned the calipers did you clean the pistons as well to get any dirt build up off the sides? If not then pump them out a little and clean them, then coat the sides with some silicon grease and it might solve the drag problem. You can buy caliper seal kits, a good investment. The only other thing I can think of is to check that the disc can float freely to centre between the pads.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
mick46
posted May 23, 2012 04:50 AM
Did you re-install the 'gaskets' between the wheel and disc, if not the discs will be slightly offset towards the wheel and could cause binding on the inside pad.
2012 ZZR-1400
Alien Frogskin Green
Brocks CT Meg, PCV & QuickShifter, Brembo M4 Monoblocs, Grimeca 320mm discs, Nitron Race shock, Gilles rearsets , adjusters and TCA axle nut, Supersprox 42T, DID nickel plate X-ring, HEL brake lines, bar risers, shorty levers, tail tidy, Zero Gravity screen, RandG spools and bar ends, GPR V4 damper.... Done !
1999 Hayabusa , stretched lowered and a 60 shot !
posted May 23, 2012 07:27 AM
Seriously, the PFM brakes are awesome afaik. We have two different issues, braking performance, and non-contact drag. Those who are serious about performance pursue both....just my .02...
posted May 23, 2012 10:00 AM
+1
CajunBoyz
posted January 13, 2014 10:47 AM
Any Feed back on peeps that may have used the Thomas Miceli caliper mods??
0.25166487693787 seconds processing time
