Thread: Crazy\'s Flys Go Bye-Bye! [ This thread is 2 pages long: 1 2 Next» ] |
CraZX14
posted May 18, 2012 01:19 PM
Crazy's Flys Go Bye-Bye!
Pulled the secondaries on the 14R. HA! I'm surprised this much fun hasn't been outlawed yet Given that I'm still at stock wheelbase, it is fun that demands considerable respect though. But aside from the extra boost in the lower range, you'd never know anything was different - still rides, idles, and sounds the same. Just some 411 for anyone thinking about doing it . . .
2003 L.E. Hayabusa
Bad in Black
posted May 18, 2012 02:33 PM
I can imagine.....I know it made a HUGE diff on my first gen. I bet that 14R has the low end thrust from hell now
CraZX14
posted May 18, 2012 03:32 PM
quote: I can imagine.....I know it made a HUGE diff on my first gen. I bet that 14R has the low end thrust from hell now
I think pulling 'em makes a bigger difference on the Gen1 - my '06 was a night and day change below 6k rpm. But without a doubt, the 14R gives a really clear wake up call in the lower gears sans flys.
2003 L.E. Hayabusa
LandSpeed
2012 ZX-14R / Blue
posted May 18, 2012 05:21 PM
What did the "operation" involve in terms of removal of parts, time, aggravation, etc.......?
I Am Rated MA-L-S-V, For Mature Audiences Only, Strong Language, Sexual Situations and Violence. View Discretion Is Advised.
Women, Racing, Boxing, Kempo and Muay Thai keep me busy.
posted May 18, 2012 06:02 PM
Edited By: smokinZX14 on 19 May 2012 01:02
quote: What did the "operation" involve in terms of removal of parts, time, aggravation, etc.......?
I have done so many i have a zipper on them .. I can install a PC and pull the flies in 3 hours start to finish with a smoke break and a root beer .. I can do the Gen 1 a little faster , about two hours with a smoke break and a soda ..lol.. If you have never done it , it will take you a Sat or Sunday to do it ... Just don't rush it , take your time ..
CraZX14
posted May 18, 2012 09:28 PM
Yeah, Lee's the man so what he said! However, I had mine pulled from a performance shop. I'm ok with a wrench, but I stripped a screw on the Gen 1 when trying to remove them myself - maybe I didn't heat the screws up enough or have the optimal screwdriver - regardless, I ended up putting it back together and bringing it to the shop (Sims). So this time around, I decided to let Sims do it again. If I was more mechanically inclined, I would have tried it again myself. Oh well, now I just have to worry about staying on the bull
2003 L.E. Hayabusa
shotgun15
quote: Pulled the secondaries on the 14R. HA! I'm surprised this much fun hasn't been outlawed yet Given that I'm still at stock wheelbase, it is fun that demands considerable respect though. But aside from the extra boost in the lower range, you'd never know anything was different - still rides, idles, and sounds the same. Just some 411 for anyone thinking about doing it . . .
Sooo...PCV not needed?
12 ZX-14R, 08 C-14, 00 ZX-12R,
90 ZX-11, 78 Z1-R
CraZX14
posted May 18, 2012 09:43 PM
I know that the PCV isn't "needed" with just an exhaust on the 14R, and (at least with Brock's), the same mapping is used with flys in/out. So logic would lead me to believe that yes, you can get away with it. However, I do have a PCV and have had it since the exhaust swap, but the guys on here that ran 'before and after' will tell you the bike runs smoother / better with a PCV.
2003 L.E. Hayabusa
sands
posted May 20, 2012 11:01 AM
That's nice to know...When I test rode the new 14r I thought the low end (4,000 rpm and lower) would be huge but I was disappointed...Good to know it's just the flys.
www.nonationalid.com
CraZX14
posted May 20, 2012 12:19 PM
quote: That's nice to know...When I test rode the new 14r I thought the low end (4,000 rpm and lower) would be huge but I was disappointed...Good to know it's just the flys.
Yep,14....14R.... Both make a big difference with flys out in the low range.
2003 L.E. Hayabusa
dogg24
posted May 20, 2012 02:33 PM
I know everyone says use a #2 screwdriver, but another option I used was a number 1 with the tip ground down so the end was flat and it fit like it was made for those screws.
2012 ZX14R SE, Streetmeg, PCV
posted May 20, 2012 02:38 PM
Can i say it ? please please , pretty please ...?
Ok i'll say it anyway .... I TOLD YOU SO ...lol
cls
posted May 20, 2012 02:40 PM
Crap! I thought we were going to be able to skip the 'fly removal on the '12. I reckon not. All righty, then: 'flies and ECU reflash left to do.
CraZX14
posted May 20, 2012 05:06 PM
LOL!!
2003 L.E. Hayabusa
CraZX14
posted May 20, 2012 05:13 PM
quote: Crap! I thought we were going to be able to skip the 'fly removal on the '12. I reckon not. All righty, then: 'flies and ECU reflash left to do.
With the potential for the bike to go into "protection mode", removing them on the 2012 is more important than ever for those of us classified as performance junkies
2003 L.E. Hayabusa
imoXu
posted May 21, 2012 12:49 AM
All this talk of flies has got me curious.
Essentially it boils down to this.
Is there any reason I wouldnt want to remove my flies?
Unless the answer is somethign I have to worry about the next question is how to I do it? Or should I get my mechanic to do it at the 6000Km service, due in a week or two
moX
zoldar
posted May 21, 2012 01:29 PM
quote: I know everyone says use a #2 screwdriver, but another option I used was a number 1 with the tip ground down so the end was flat and it fit like it was made for those screws.
use a JIS screwdriver....not a phillips
Kaw Man
posted May 21, 2012 03:38 PM
Crazy when r u going back to track.
kaw-rick
posted May 21, 2012 03:54 PM
just pulled mine, crazy throttle response now. the screws came out very easy also. i geuss ill have to slip into another track somewhere to see if it helps.
CraZX14
posted May 21, 2012 04:44 PM
quote: Crazy when r u going back to track.
On Wednesday.
2003 L.E. Hayabusa
Greggy
posted May 24, 2012 03:19 AM
Crazy have you had any issue, glitches or error codes with the 14R since pulling the flys and no doubt getting some miles on her in that configuration?
I'm so tempted to pull the trigger and get my flys removed too but don't want to run into a fault.
Greggy
2012 ZX-14R ABS - Spark Black - Two Brothers V.A.L.E. Carbon slip ons P1X tips - Powerbronze DB screen
cls
posted May 24, 2012 05:46 AM
Yep, I'm pulling mine. Am I also to understand adding a TRE008, in addition to removing the 'flies, will kill the "protection mode" for the R? Or is it one or the other?
drewzx-14
Andrew
posted May 24, 2012 06:01 AM
Have you experienced a significant difference in fuel economy since you have pulled your flies?
2009 Yamaha R1
CraZX14
posted May 24, 2012 09:59 AM
quote: Crazy have you had any issue, glitches or error codes with the 14R since pulling the flys and no doubt getting some miles on her in that configuration?
Greggy[/quote
quote: Have you experienced a significant difference in fuel economy since you have pulled your flies?
No issues, glitches, codes, etc. Just don't bend the bar they're attached to and you should have no problems.
I haven't ridden enough with them out to tell about the mpg.
2003 L.E. Hayabusa
Bishopzx12
posted May 24, 2012 12:40 PM
Anyone clsoe to the SC area that may pull mine when i get it
1996 ZX7R
1999 ZX9R
1999 ZX11
2000 ZX12R 1270
2002 GSXR 1000 "I was Drunk"
2003 ZX12R 1375
2006 ZX14
2012 ZX14R
| Quick Reply: |
