BIKELAND > FORUMS > ZX-14.com > Thread: coolant bottle boiling over?? NEW TOPIC NEW POLL POST REPLY
tking
posted May 15, 2012 12:49 PM
I'm having an issue and looking for some insight. 08 zx14 heats up pretty quickly but doesn't actually over heat but does get to 5 bars within 5 minutes but when I shut it off, the overflow fills up and pukes out of the tube, when it cools down it pulls the coolant back in from the resivoir
shawnski
posted May 15, 2012 01:05 PM
Could be a lot of things... 5 bars is running too hot that is what it wants to overflow... Could be faulty thermostat ... Does the fan work??
tking
posted May 15, 2012 01:07 PM
yes fan comes on at 4 bars
smokinstorm
Old Drag Racer
posted May 15, 2012 01:17 PM
Yours is running too hot unfortunately. Mine too so you're not alone. Make sure your radiator fins are not plugged up with anything. I'm going to take my thermostat out this week to buy me some time before the bike heats up. I'm also going to install a second fan and you may have to do the same as well. I'm even going to put on a ZX10 front fender as soon as money avails itself.
2009 Monster Edition ZX14
It's all stock I swear. Well...almost.
2005 Turbo Busa
2001 GSXR 1000
Looking for a 1985 GS1150E
tking
posted May 15, 2012 01:19 PM
It started doing it the other day at the track after a few runs.
dakota9498
posted May 15, 2012 01:26 PM
Must be a closed thermostat, it shouldn't be running that hot that quick. With the short time it is taking to get to five bars and the pressure afterwards, the thermostat would be my best guess. Hope you get it fixed, let us know how it turns out.
2008 ZX14
posted May 15, 2012 01:39 PM
Question ? did you have the bike apart for any reason before this happened ?
tking
posted May 15, 2012 01:40 PM
Milled the head a couple months ago, nothing since then.
posted May 15, 2012 01:44 PM        Edited By: smokinZX14 on 16 May 2012 03:45
Some thing you might want to Check .. I did this myself and had the same problem as you ... If you look there are two hoses going to the rad cap .. One is and over flow and the other is a by pass to the engine .. I had them switched and it ran hot every pass and when i turned it off in the pits it puked water out of the coolant tank ... Might not be the problem but it's worth a look see ..
tking
posted May 15, 2012 01:51 PM
lol, I had that problem when it first went back together. Was fine for 2 months then at the track the other day it was bike night so not a lot of people there but of course not a lot of traction either. 4 passes within an hour and it puked the coolant, let it cool for an hour and ran it again and all was fine. Ran 3 passes in a row and it did it again so called it quits for the night. Rode it to Brocks to have it tuned today which is less than a 5 minute ride and it was at 5 bars and was puking in the parking lot. So I took it back home
posted May 15, 2012 01:58 PM
well it was worth a shot I have milled a few head on zx14s and never had a problem with over heating .. I guess it's possible that you pushed a head gasket into a water jacket causing a build up pressure in the cooling system .. Zx14 just don't seem to have head gasket problems other than big boost or a lot of spray , even then it's rare .. Check you stat first , if that is ok do a leak down or compression check ..
tking
posted May 16, 2012 01:29 AM
Pulled the head off this morning and I don't see it blown but there are places where it looks like the head wasn't really touching and I didn't notice before but the cut on the head seems to be kind of a rougher finish than I usually see, feels like a record with my nail against it?
posted May 16, 2012 05:47 AM
I should be a very fine cut, no cutting marks , book calls for a smooth cut ... could be not sealing because of that..
tking
posted May 16, 2012 08:09 AM
Well I took it to the machine shop and they said that it also need exhaust valve guides? This motor has 7k miles on it and was untouched until 2 months ago. So looks like its going to get a valve job too, Should I have them sink the valves in .030 and mill another .030 off the head while I'm at it and at least get a little more power out of it?
Newjack
posted May 16, 2012 01:42 PM
Sounds like the roughness area (RA) was too high. On my turbo motors I would lap them with 1000 grit wet sandpaper if the surface was too rough from the machine shop. You can get a mirror polish if so desired with a little elbow grease. On a less than smooth surface, copper spray helps too but is a bitch to clean off next HG change.
tking
posted May 20, 2012 09:05 AM
Well I head a completely different head done exactly as mine was except a nice finish. Runs great but gets up to temperature pretty fast and runs at 4-5 bars, after it hits 4 bars the fan comes on and stays hot enough for the fan to stay on?? Not spewing coolant out just yet but I've only rode it 2 times 15-20 minutes each time
zixxer14
Damn that was Quick
posted May 20, 2012 01:12 PM
You need a zx-10 ten fender conversion. It will drop your running temp at least 1 bar plus using engine ice will add cooling efficiancy. You can also add a 2nd fan to increase cooling.
posted May 20, 2012 04:03 PM
a lil test
note the level in the overflow, mark it
heat until fully heat soaked, fan comes on for a bit
note coolant level in overflow, it should have come up a couple inches or so
with motor running, look carefully in the overflow for bubbles
if bubbles, you have a bad HG, if none HG prob good
shut off motor, let motor cool completely and coolant level should fall to exactly were it was before test.
If it falls more than at start, you just got rid of air in the coolant system.
repeat heat cycle until the level before & after is same, then all air is gone.
On my 12 it usually took 3 heat cycles to purge all air; my Busa only 2.
Just a test...
0.47087001800537 seconds processing time
