BIKELAND > FORUMS > ZX-14.com > Thread: top speed 140mph NEW TOPIC NEW POLL POST REPLY
ninjawilk1
posted April 08, 2012 06:32 PM
top speed 140mph
i have a 06 14 . when i get to 140mph at 7000rpm in5th gear. it stop pulling like it is at toped out. i have pc3 usb ,tre ,street meg..
kawasakiman
02zx12rbob
posted April 09, 2012 04:04 AM
Somethins not right ....
zx996
posted April 09, 2012 04:22 AM        Edited By: zx996 on 9 Apr 2012 11:29
Try disconnecting the PC.if it starts pulling there's your problem. Also check your air filter,the ram air works so good it sucks in everything. Mine was so plugged it looked like clay in there.I have even found little parts of gixxers in there as I blow by
The big blue whale 06zx14 and the big red bus 01 busa,red rocket 02zx12
Oz Booster
posted April 09, 2012 02:32 PM
Check your fuel flow, internal filter may be getting blocked
madkawboy
posted April 09, 2012 03:31 PM
A friend of mine had the same problem on his B-KING. It turned out that it was a clogged up fuel injector from the bike siting for a period of time. The local BMW dealership had a pressurized fuel cleaning machine and it fixed his problem.
2007 ZX-14
Stock Wheel Base, footshifting, pump gas
5.94 @ 128 mph
1.50 60ft
ninjawilk1
posted April 10, 2012 06:18 AM
Oz Booster where is the internal filter. madkawboy.. do i remove the injecters THANKS FOR ALL THE HELP still trying to figer it out....
kawasakiman
Bigbore4
posted April 10, 2012 06:36 AM
Check the ground on your pc. Run it direct to the battery.
posted April 10, 2012 07:57 AM
in the tank
07 MDP Rookie of the Year
01 ZX-12R 8.84 @ 156.3 no bars, DOT rubber, Pump Gas NA..... turbo 8.47 @ 164
00 ZX-12R 8.62 @ 165.2 no bars, slicks, Pump Gas, 55 shot
00 ZX-12R stock with bolt ons NA 203.694 Loring 2012
Warp 12 Racing!
madkawboy
posted April 10, 2012 10:33 AM
No, you don't have to pull out the injectors.
2007 ZX-14
5.94 @ 128 mph
1.50 60ft
Big Earl pearl
Get rich to this
posted April 10, 2012 03:15 PM
ninjawilk1 did u find the problem?
Oz Booster
posted April 10, 2012 03:22 PM
better to test flow than try and see if the filter is blocked
There will be a wire from the fuel pump relay that runs to the ecu , the ecu gnds this to turn the pump on, not familiar with the kawasaki wiring or colors yet so someone here may be able to identify it ,
If you stick a piece of stripped back wire in beside that wire from below and bolt the other end to a good ground point you can then use the key to turn on the fuel pump
run a hose from the tank outlet to a container and key on for 30 secs , you should be able to compare the volume with specs from the manual
but basically i would be looking for 400cc or more (800cc/min)
be carefull around raw fuel
Ozonkiller
posted April 10, 2012 04:11 PM
Don't forget fuel tank venting
Quick Reply:
0.209861040115 seconds processing time
