venomous_zx
2012 14r - low and long-
posted March 10, 2012 06:34 AM
2nd gear to neutral slip
i was riding one day.... just taking off from a light. kick into second gear then a few seconds later as i twist throttle the bike drops second gear and slips into neutral int he middle of the street... anyone have this happen? i figured its the oil... still has new bike break in oil.... only 300 hundred miles. well im gonna change oil when i get home.
sensei
RICH CRAFT 1
posted March 10, 2012 07:06 AM
you probably didn't get it all the away in to second gear. this usually happens when the shift dogs or worn out. Being a new bike, I doubt this is the problem. but if he keeps doing it. You might want to look at a warranty thing with the dealership.
Ken
Red 06 ZX14 RR
venomous_zx
posted March 10, 2012 07:24 AM
I also thought that as a possibility. Maybe I didnt fully seat it into gear.
sensei
chriszx14R
posted March 10, 2012 07:34 AM
I moved the shift lever one spline so the lever is down a little from stock. For sure you didnt get it all the way into gear. this would happen on any bike except honda GP trans.
2002 ZX12R
2004 ZX10R
2012 ZX14R
shawnski
posted March 10, 2012 07:37 AM
quote: you probably didn't get it all the away in to second gear. this usually happens when the shift dogs or worn out. Being a new bike, I doubt this is the problem. but if he keeps doing it. You might want to look at a warranty thing with the dealership.
Ken
+1
venomous_zx
posted March 10, 2012 08:14 AM
Ill look into.moving the lever if it persists
sensei
samin
posted March 10, 2012 12:23 PM
Edited By: samin on 10 Mar 2012 20:35
14 or 14R? I´ve slipped gears many many times on my 11 and 14. If you dont synchronize (thottle, clutch and leveler) your shifting properly, you can slip it. So no worries.
You can shift 1->2 even w/o clutch if you pre-load gear leveler gently and blib the throttle.
My video
*Who's General Failure and why's he reading my disk?
* ZX-14 ABS -08, Finnish guy ^^
venomous_zx
posted March 10, 2012 01:48 PM
My previous bike I always shifted without the clutch after 1st gear. It only happened once but I was like wtf..
sensei
samin
posted March 10, 2012 02:48 PM
quote: My previous bike I always shifted without the clutch after 1st gear. It only happened once but I was like wtf..
everyone has its first time
venomous_zx
posted March 10, 2012 04:30 PM
I guess my cherry was popped....
sensei
samin
posted July 20, 2012 04:48 PM
Somehow I managed to slip 6th back to 5th?
How can that happen?
Got confused and hit limitter
Seno
BANNED FOR LIFE!
posted July 20, 2012 05:32 PM
+2 , Don't think it was fully in gear. My 14R only poped out once and it was due to a "weak shift" at WOT...
