BIKELAND > FORUMS > ZX-14.com > Thread: push pins for undertail NEW TOPIC NEW POLL POST REPLY
Rajun Cajun
posted March 07, 2012 06:26 AM
HEY GUYS! Have anyone one of you hade problems with keeping the plastic push pins in the under side of the tail section on your bike? I replaced them and made sure they were pushed in all the way and the DARN THINGS CAME OUT!
Candy Thunder Blue 2006 ZX-14, +1 rear, RoaringToyz blocks, windscreen spikes! (VERY SHARP! DO NOT TOUCH!!!!)
Time lost can not be retrieved! Its not dumb to ask questions. Rajun Cajun
Rob7R
More balls than brains.
posted March 07, 2012 06:42 AM
No problems there. My problem is with the darn screws that go into the side of the gas tank cover near the seat, I bought a whole set of fasteners for the bike when I bought it, and put new ones in. Wouldn't you know one of them vibrated out within a few months. The threads didn't grab very well in the first place. Guess I need to figure out what they screw into and see if it's safe to tap new threads in it.
Current bike- 07 ZX14 black with D&D cans, PC3, 43t rear sprocket, 6 inch extensions, roaring toys lowering links. Muzzy Bonneville Pro, TRE Velocity stacks, Puig DB windscreen, Sargent seat, Heli-risers, and throttlemeisters.
Rajun Cajun
posted March 07, 2012 07:18 AM
DARN! I'd be upset too!
I don't like how the rubber capture nut(I'm not sure of the correct name to the part) that the screws are to fasten to are deteriorated and hard to put back inplace!
posted March 07, 2012 07:29 AM        Edited By: Shane661 on 7 Mar 2012 15:30
Monitor the wellnuts closely. They can come apart and be injested by the engine, at a significant cost. Poor design that also carries over to the 14R....
Rajun Cajun
posted March 07, 2012 10:10 AM
Thanks Shane661!
venomous_zx
2012 14r - low and long-
posted March 07, 2012 10:29 AM
Rajun, maybe the holes are worn. That may be the cause that those plastic clips dont get enough bite. This may sound dumb and dont take offense but are they the right size clips? Ive never had that problem even with semi broken clips
sensei
Rajun Cajun
posted March 07, 2012 11:25 AM
Yes sir! They are the right ones... I went to Fox's Suzuki in Roxborro, N.C. to show them my bike, where they would be located and that they are the same as the ones on the 2010 and 2012. I will check for the wear in the hole size. I will put a new one in and see if I did not push them all the way through to the black plastic.
venomous_zx
posted March 07, 2012 01:48 PM
I hate those clips. Let us know what you find is the cause
sensei
Rajun Cajun
posted March 07, 2012 03:53 PM
ok I will
Rob7R
posted April 23, 2012 11:29 AM
Thanks Shane!
I took the gas tank cover off and sure enough one of the wellnuts was almost ripped in half. Unfortunately I couldn't get it out without it ripping and it fell in. Had to lift the tank and remove the cover and fish it out. I wouldn't have known to do that if not for you. In fact I'm pretty sure I would've assumed it would eventually fall harmlessly to the ground. Good looking out! This forum is the best.
Interesting side note. My bike has no flies. It has a tremendous power surge at 6000RPM so I thought they were still in there. I guess I gotta find a new map and see if I can't smooth out the power delivery.
Thanks again!
Rob
ZX14 Montana
posted April 23, 2012 04:19 PM
I am no push pin expert... I know that the 14's have at least a couple different sizes of push pins, and if you didn't know that, it is very easy to put the different version's in a hole that takes the other, etc. etc. One thing I do with push pins in most applications for the 14 is take the whole pin apart, you will have two seperate pieces of course, and install the main body, or female end, if you will, and install the pin when you can see, or, feel how far past the whole, the push pin body is going...granted, that is easier said than done. With push pins, it is easy to miss the different sizes, (sometimes) you can't always see where the pin will go...but you can see many of them... Plus the other comments made on this post, are ones I would consider.
posted April 23, 2012 05:12 PM
I thought there was only one size push pin. The ones under the nose are different?
ZX14 Montana
posted April 23, 2012 06:28 PM
Yes...there are two different sizes...the nose section, the inner black plastic, and where some of the rubber skirting fastens to the inner fairings, just under the George Foremans...
INTIMIDA2OR
RED rider!
posted April 23, 2012 08:45 PM
What!? The 14R has that same problem? Damn that's fucked up.
'06 Passion Red ZX-14
*Lee*
Rajun Cajun
posted April 24, 2012 04:33 AM
I went to Lowes and got some for a car! They are working fine!
BobC
posted April 24, 2012 05:06 AM        Edited By: BobC on 24 Apr 2012 13:12
It's surprising that this crappy piece of design was carried over to the 14R, especially since Kawasaki do seem to have listened to feedback and sorted out a lot of the shortcomings of the original model. Probably no warranty claims from wellnuts being ingested and no performance gain for changing it.
How hard would it be to use a hank bush in there, or at least a small guard to keep the wellnut from falling into the airbox?
I just keep a real close eye on mine and put those upper bolts back in the George Foremans carefully.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
0.22189593315125 seconds processing time
