BIKELAND > FORUMS > ZX-14.com > Thread: Wiring for air shifter on new 2012 14r only NEW TOPIC NEW POLL POST REPLY
KAWITOM
My 12R gone but not forgotten
posted February 22, 2012 06:43 PM
Here is a neater drawing of the setup for a 14r I am just putting it out there for anyone who wants to use it. It works great on my bike I have already tested it. Lee doesn't want to use because of problems he had. The biggest thing is to cut the wires BEFORE the connector for the left handlebar switch assembly (leave the factory wires alone after the connector which is located to the left of the ram air tube) The relay cost about five dollars and the switch from Radio Shack cost about four dollars. The biggest thing you have to do is to isolate a ground off one of the two wires that you cut then use the toggle switch and relay to do the rest of the work for you. If anyone has any questions just PM me I would be more than happy to help anybodf Later Kawitom
2012 ZX-14R SE
2002 VULCAN MEAN STREAK (11.41 @ 114 best 1/4)
I BLEED GREEN
Wheelie
Old Man
posted February 22, 2012 06:55 PM        Edited By: Wheelie on 23 Feb 2012 03:02
worked for me, cut the wires near the horn button, not after the connector down by the horn like Tom said. I mounted a toggle switch so I can turn the horn button on and off if I want to use autoshift.Thanks KAWITOM
wee
KAWITOM
posted February 22, 2012 07:04 PM
no problem Wheelie good luck this weekend
2012 ZX-14R SE
I BLEED GREEN
Lucky14
posted February 22, 2012 07:16 PM
Any time there is a discussion about using the horn button for the air shifter, I think of Smokinzx14's story. I did a search for it to get the exact quote:
"My second pass was really funny , As i shifted from first to second gear i hit the horn button 3 times before i remembered i didn't have and air shifter !!!!"
zx13r
Capt-America
posted February 23, 2012 10:13 AM
Is it possiable to just use the positive that comes from the horn to activate the power on the solenoid and the mps box to trigger the airshifter, and just ground the blue and black wire from the mps box and solenoid?
Sposored By:
Kawasaki Sports Center
ShoTime Graphics.com
0.21644997596741 seconds processing time
