mad_matthew
posted August 26, 2011 04:24 AM
Bottomed out, advice from experts req!
G'day,
Names Matt and I am a bit of a newbie when it comes to the actual mechanicals of a motorbike. I have owned a zx12r and have recently bought a zx14r 2011 model which I love. I have done only maintanence work on it like oil change etc. Recently I was arriving home in the dark after quite a nice ride - riding over my front lawn at about 7km/r and then there was a god awful scraping sound. Turns out there was half a brick hidden in the grass and it the bike bottomed out on it really hard. I could not feel any oil leaks but the drain bolt looks a bit mangled and there are these little fin things that are cracked and falling off before the bolt.
Have I just completely screwed my bike? Is there a possiblility the impact could of caused micro fractures through the engine and loosen seals or something? What is the best way to go about repairing the damage?
Any advice would be truly appreciated. Oh man I am stressing..
posted August 26, 2011 04:54 AM
Just check for oil leaking...If not then you have nothing to worry about...If its leaking tighten the drain plug and if it still leaks then you'll need a new oil pan...That would be the most of the damage, your motor is fine!!!
Newf14
2007 ZX1400
posted August 26, 2011 06:06 AM
If there is no leeks cut off the little fin and I will send you a low profile drain plug. Just P.M me you mailing info.
Newf14
glarior
posted August 26, 2011 08:23 AM
Just what they said, double check for leaks and you will be good.
My fins were ripped off when it was bottomed out on a trailer and never had a problem with leaks.
Texas Mile - 201mph
LTA - 221.18mph track record... for now
Mojave Mile - 213.2mph
Texas Mile Beeville - 210.5
http://www.youtube.com/user/horsepowerMafia
osr
posted August 26, 2011 09:44 AM
PUll your pan and send it to us to cut and modify for a low pro pan.
Rook
posted August 26, 2011 12:54 PM
You just made the bike a bit more wheelie safe. Shaved a half inch of wasted ground clearance. I doubt if anything was damaged at all except fpr the drain plug protector. Dremmelthat sucker off and go low profile bolt. IDK a thing about the low profile pans. Only thing you would want to avoid was making the bike more prone to oil starvation. There are a few that have thrown rods through the motor from not getting sufficient oil.
Rook
posted August 26, 2011 12:58 PM
The front is very soft on the 14. Sounds like you encountered a situation that you are not very likely to need to deel with on a regular basis. Still have a look at adjusting the sag or at least stepping up the preload on the front.
I felt the rear was set too hard for me and front much too soft. I was tapping bottom a lot before i made some adjustments.
mad_matthew
posted September 02, 2011 05:44 AM
Thanks for all the advice guys, I really appreciate it.
bradkong12
posted September 02, 2011 09:57 AM
Hey rook,
i am needn low profile plug BAD, i tryd 2 PM u but cant
thks
bradkong12
motomoto
posted September 02, 2011 11:50 AM
quote: PUll your pan and send it to us to cut and modify for a low pro pan.
How much is this? Also how do I get a hold of you?
joel787
posted September 02, 2011 12:08 PM
Go to his website
Wheelie
Old Man
posted September 02, 2011 12:19 PM
quote: If there is no leeks cut off the little fin and I will send you a low profile drain plug. Just P.M me you mailing info.
Newf14
^ that
wee
Rook
posted September 05, 2011 08:51 AM
thks
Sent you a PM back bradkong. I was just quoting Newf up there. He is the guy who has the low profile drain plugs, not me. So PM Newf14 for that item.
osr
posted September 06, 2011 07:15 AM
$125 exchanged 317-523-4049
bradkong12
posted September 08, 2011 01:52 PM
thks osr , hitn u up when cash is good
bradkong12
