BIKELAND > FORUMS > ZX-14.com > Thread: well I'm an idiot NEW TOPIC NEW POLL POST REPLY
1badzx12r
posted April 03, 2011 04:54 PM
well I'm an idiot
well its like this my new gtr1400 transmission in a zx14 motor .... I'm beginning to like this launching in 2nd gear stuff total of 15 passes so far .. yes you heard me right 2nd gear .... i'm such a fukking idiot ..
ZX14Mike
posted April 03, 2011 08:54 PM
Is 2nd alot lower on the GTR tranny?
Superman T
posted April 04, 2011 02:29 AM
What difference are you experiencing between 1st & 2nd? & yes u r an idiot
rocket2117
rocket2117
posted April 04, 2011 03:12 AM
1badzx12r
posted April 04, 2011 04:58 AM        Edited By: 1badzx12r on 4 Apr 2011 15:51
2nd gear on a connie is taller than 1st gear on a zx14 by a little
i don't use 1st at all .. but its 200 rpm difference at 4000 rpm ..
but what i do know after 15 passes is my 60 fts went from low 1.40's with a zx14 transmission to mid 1.40's with the gtr14 transmission using the same sprockets I've run for a year now .. but my ET' improved with less mph and in a 20mph headwind and 90 degree humidity and rich A/F's .. when i get this all dialed in i think its gonna be worth the effort .. I'm such an idiot i should just quit now ..
Compton
posted April 04, 2011 05:04 AM
may sound dumb, but will this trans shift into 2nd from neutral?
b.w.
1badzx12r
posted April 04, 2011 05:06 AM        Edited By: 1badzx12r on 4 Apr 2011 13:35
not at a stand still it won't .. but if rolled forward it will ..
i roll up and do my burn out in 2nd .. but yes next time i go into the motor it will because i'm going to dismatle the 2nd gear lockout and i will install the connie 1st gear for the hell of it
1badzx12r
posted April 04, 2011 05:12 AM        Edited By: 1badzx12r on 4 Apr 2011 15:40
Gear Ratio 1st 3.333 (50/15) 2nd 2.415 (41/17) 3rd 1.900 (38/20) 4th 1.545 (34/22) 5th 1.292 (31/24) 6th 1.074 (29/27) this the gtr14 gear ratio
Gear Ratio 1st 2.625 (42/16) /2nd 1.947 (37/19) / 3rd 1.545 (34/22) / 4th 1.333 (32/24) / 5th 1.154 (30/26) / 6th 1.036 (29/28) this the zx14 gear ratio
note 2nd gear on the connie 2.415 (41/17) vs the zx14 1st gear 2.625 (42/16) .. now i don't understand why i was fighting wheelies .. i didn't know how this was gonna work until i tried it .. now i'll play with it more and get some bugs out .. but it sure is nice getting rid of an extra shift
zixxer14
Damn that was Quick
posted April 04, 2011 07:18 AM
If your numbers are right the zx-14 gears are lower in first than the connie's 2nd gearing ie. 2.625 is a lower gear ratio than 2.415. Are the gears interchangable between models? If so you could create custom gear ratios to play with.
1badzx12r
posted April 04, 2011 07:38 AM        Edited By: 1badzx12r on 4 Apr 2011 15:54
numbers are from KHI
yes you right my bad .. IT was too early in the morning for me .. all gears are interchangable but 1st gear due to gear being made on input shaft .. and you have to change or use the shift fork thats on the shaft by itself to the connie transmission when using the connie gears
1badzx12r
posted April 04, 2011 07:39 AM        Edited By: 1badzx12r on 4 Apr 2011 15:51
the input shaft on a connie is about a 1/2 inch longer due to the slipper clutch on a connie is the only reason i didn't install 1st gear
epd345
posted April 04, 2011 01:13 PM
Why not just gear it up with like a 36 or 38 tooth rear sprocket?
1badzx12r
posted April 04, 2011 02:27 PM
you tried leaving with a 36 or 38 gearing ..
epd345
posted April 04, 2011 03:21 PM
Yea but if your first gear is that low then it shouldn't it make the lower tooth count managable since your first gear is that low? Im no expert here, just guessing?
1badzx12r
posted April 04, 2011 03:38 PM
and why make it 3 shifts in a 1/8th mile when i can do it in 2 shifts
wrongway
posted April 04, 2011 03:44 PM
i just did the calculations .....
18/38 sprockets with the concours tranny was the same over all gearing in 1st gear as
16/42 sprockets on a zx14 tranny ( assuming that they both have 1.541 primary ratios)
with a 213 mph top speed
but it does show a 2000 rpm drop on the gear shifts.... might be a bit much for normally aspirated motors.
Roy
1badzx12r
posted April 04, 2011 03:54 PM        Edited By: 1badzx12r on 4 Apr 2011 23:58
thanks roy .. I'm having fun with it .. my last outing i only had around 250 hp to the wheel and at 830lbs ran 8.80's at 154mph into a 20+mph head wind rich A/F and 90% humidity .. i was shock i didn't expect that ..
Superman T
posted April 04, 2011 06:24 PM
That's moving 1bad, cudos for hittin 8's.
Big Mete
You Rang
posted October 29, 2014 06:53 PM
I know this is extremely old but i am looking for 1bad to ask him if the gtr1400 transmission gears can fit into a 2012 zx14r?
come at me sideways
and i will straighten you
out
BIKELAND > FORUMS > ZX-14.com > Thread: well I\'m an idiot NEW TOPIC NEW POLL POST REPLY
0.33659601211548 seconds processing time
