BIKELAND > FORUMS > ZX-14.com > Thread: resistor question NEW TOPIC NEW POLL POST REPLY
1badzx12r
posted March 23, 2011 02:03 PM
resistor question
ok got rid of the in tank fuel pump .. now i need to get rid of the flashing gauge .http://www.bikeland.org/board/viewthread.php?FID=27&TID=47458&set_time=1243642952
this was never answered on what size resistor ..
Compton
posted March 23, 2011 02:06 PM
Just ground it i guess works.
b.w.
1badzx12r
posted March 23, 2011 02:06 PM        Edited By: 1badzx12r on 23 Mar 2011 22:31
nope that blows the fuse to the ECU ..
what happen was i grounded the wire ... the fuse busted to ECU i installed new fuse ..the gauge stop flashing ...but the fuel gauge is flashing .. and just the fuel gauge only ..
Compton
posted March 23, 2011 02:43 PM
oh, i put up pictures of the OHM readings before on this site. if that helps, i dunno. i
b.w.
Compton
posted March 23, 2011 02:49 PM
dry
wet
b.w.
1badzx12r
posted March 23, 2011 05:18 PM
THANKS .. But 1 thing i is not is an electrician . somebody gonna have to tell me what resistor to use ,,
what i found by more try and error is that with the low fuel sensor attached and grounded to the frame... it works for 2 minutes then goes to flash mode ..
dakota9498
posted March 23, 2011 05:46 PM
1.3k ohms, should be able to go to a radio shack, or just pick one up online.
http://www.google.com/search?q=1.3k+ohm+resister&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a#q=1.3k+ohm+resistor&hl=en&safe=off&client=firefox-a&hs=FoF&sa=X&rls=org.mozilla:en-US:official&prmd=ivns&source=univ&tbs=shop:1&tbo=u&ei=SKKKTbOGNtSz0QG7zsDtDQ&ved=0CEIQrQQ&biw=1440&bih=685&bav=on.2,or.r_gc.r_pw.&fp=a40f3cd63ecc4954
2008 ZX14
1badzx12r
posted March 23, 2011 06:18 PM
thanks ..thats kinda what i taught i needed .. i'll get a few tomorrow from radio shack ..
dakota9498
posted March 23, 2011 06:35 PM
Just make sure you get one with a high enough wattage rating that it doesn't burn up.
2008 ZX14
1badzx12r
posted March 23, 2011 07:30 PM        Edited By: 1badzx12r on 24 Mar 2011 03:31
now you gonna make me go look in the manual again .. or are the like a standard wattage .. like 10 100 1000
quick6
posted March 23, 2011 08:37 PM
could try a pot. works the same as a resistor, but it is adjustable
2006 zx14, fully dressed and sliding(Charlie Sheen)
1badzx12r
posted March 24, 2011 04:41 AM
looks like 3.4 watt @ 1.3kohms is my critter ..
1badzx12r
posted March 24, 2011 05:19 PM
ok best i could find was a 1 watt .1.3 k ohms .. installed it inline and works perfect .. ps ...my new external fuel pump puts out so much fuel i may just have to go negative in the 100% throttle on full boost
Compton
posted March 24, 2011 07:25 PM
Nice! glad the pics helped out.
b.w.
0.23788499832153 seconds processing time
