BIKELAND > FORUMS > ZX-14.com > Thread: valve cover leak NEW TOPIC NEW POLL POST REPLY
Lou D
posted March 14, 2011 04:11 PM
valve cover leak
Can anyone give me some advice on adding the 10mm washers to the valve cover bolts. Can I get to them by just removing the tank? Thanks
  Ignore this member    Click here to visit Lou D's homepage.
Compton
posted March 14, 2011 04:18 PM
Tank wont do anything. To see the valve cover you need to remove the side panels
b.w.
LOCK 909
posted March 15, 2011 07:52 PM
Read up past post's It's easy fix , pull valve cover, clean gasket , or replace, use a littel Avaition from A gasket #2 on it , replace bolts, with washer's on them , take one to a simple LOWE'S hardware store , to the stainless washer bin , find one that fit's !! the valve cover bolt shaft snug and about 2 mm thick .
forma gasket sealer on the bolt heads reinstall tighten down inside out , overtighting will break or strip the small threads in the head. just a littel more squzee on the gasket is all that is needed
0.29178214073181 seconds processing time
