06redzx14
posted November 30, 2010 09:06 AM
gear/speed input on dynojet hub
is anybody using the fuel trim by gear feature on their hub? Looking to get some feedback on how well it works or whether or not it is worth trying to figure out. Looking to add more fuel on the top end of a run instead of having it the entire run.
06redzx14
posted November 30, 2010 12:17 PM
Compton
posted November 30, 2010 04:24 PM
I use it to pull timing, works fine. i add fuel a different way so i cant comment on how well that works
b.w.
06redzx14
posted January 02, 2011 05:22 PM
Think I'm going to try this out. Does anyone know what wire is the gear sensor?
06redzx14
posted January 03, 2011 07:09 PM
Found it green/red wire in the 4 wire connector on sprocket side of the motor. Any input on adding more fuel in gears 4-6 to compensate for ram air? My indicator never goes above 5 though
