BIKELAND > FORUMS > ZX-14.com > Thread: Exhaust Review: Muzzys, Brocks, Tsukigi, Ti-Force... round 2 NEW TOPIC NEW POLL POST REPLY
gilberjj
Friend of Fast
posted November 28, 2010 05:23 PM        Edited By: gilberjj on 29 Nov 2010 01:27
Most of this has already been posted by me a while ago but none of the pictures were showing up, plus I have another exhaust to add.... So I thought I'd just start a new thread...
This post is from my thread about pictures of my bike, but since I spent so much time doing this writeup, I thought it would be worth making just a thread about all the different exhausts I've used throughout the 2.5 years of ownership of my 2006 zx14. With all the exhausts, my bike setup has been the same (save for installing a 16t front sprocket for a short stint on the Muzzy m10 and Brocks Alien Head).
My bikes consists of the following....
2006 Kawi zx14
PCIII usb
Flies removed
Pipercross race filter
The exhausts I've used are....
Stock (obviously)
Tsukigi
Muzzy m10 (the original, not the m14/m10)
*Important note: The Muzzy pipe I was using was the original design. Since that time, Muzzy has come out with the stepped header m14 version. That pipe is lightyears better then the original that I tested. It is fully tig welded, and quality of build is on par with, or better then the Brocks imo. Sticks m14 equipped bike romped my bike on two seperate dyno days (Tsukigi and Brocks equipped). Comparing other m14 equipped bikes, I've come to the conclusion that his bike just finds another 4-5 whp. All in all, get an m14, not an original muzzys...... cause the originals suck.
Brocks Alien Head
Orient Express (this exhaust is made by Ti-Force for Orient Express)
Brocks Sidewinder
Muzzy m14 prostock sidewinder
*Important note: I never actually put this on my motorcycle. I just turned it, so I don't have an opinion about power, sound, etc. However, it was made of high quality materials, and the tig welds were of a much higher quality then the previous generation Muzzys exhausts. I have seen other m14 exhausts, and they are very nice, which makes me recommend the m14 OVER the standard muzzy exhaust.
Power: I like the alien head and the orient express the best. The alien head undoubtedly makes the most hp out of all the pipes. It's noticeable in the ride! The alien head used to loft the tire so badly in 2nd that I had to go back to a 17t front sprocket. None of the other pipes did that. All the 3 other exhausts are similar in power (as far as I can tell). I would guess that the power goes Orient Express being second, Muzzy m10, and Tsukigi (all trailing the Brocks of course).
Quality: The build quality of the brocks and muzzy are lacking in comparison to the orient express (ti-force) and tsukigi. It's not even close! The orient and tsukigi look like works of art, and the brocks and muzzy pipes look like they were built by a muffler shop. To be fair, the muzzy pipe was even lower quality then the brocks. One thing that hurt the Brocks (as far as quality goes) was how thin the piping was. It was so thin that the spot welds for the spring tabs left large bumps on the inside of the piping. I know it's much more difficult to weld thin piping.
Fitment: Fitment was where the brocks pipes really shined. All the other pipes stick out below or equal with the oil drain plug guard, but the brocks is higher then even the sump. The Muzzys m10 was the easiest to assmble because it was just 2 pieces. All the others were equally frustrating (but not all that bad).
Sound: Though my opinion counts for little, I thought I would still air out my thoughts about the sound of each pipe. For street riding, the Orient Express is the nicest. It is deep and smooth with no raspy undertones. It's not the same deep that you get with a shorty pipe (like the m10 or alien head), but it's still deep. The sound is what you would expect from a liter bike, with 352 more ccs..... Still has that f1 high revving wail to it, but a little deeper. It is calm when riding regularly, but opens up when you get on it. The Tsukigi (I think it's muffler packing was burnt out of it), muzzy m10, and brocks all made a blat blat blat sound at about 1,500 rpms. That really annoyed me. At the track, the Muzzy m10 and the Brocks alien head sounded equally good. Real aggressive, and real deep. They aren't as deep as a Brocks Smeg or sidewinder, but they are still much deeper then a canister style exhaust. Both the Brocks and m10 were tiring on your ears if you were riding for more then 50 miles at a time. I would suggest ear plugs if you go on longer rides with the muzzy m10 or brocks alien head. IMO, the m10 is a little quieter then the Brocks, but that's like saying one sumo wrestler is fatter then another...... They are both fat...... Not that it matters too much, but the Brocks sidewinder sounded excellent. It was the deepest of all the pipes I ever owned, and it didn't have the blat sound like the other shorty systems (or Tsukigi). It was a SMOOTH deep and aggressive sound.
Mapping: With all the exhaust systems, I ran flies out. For the Tsukigi, I got a map from HPC (zx14.net). It was a good map but ran rich up top. I considered getting a custom map as I suspected the map was a little fat in areas. All in all, it was a good map, but down on power compared to the others. When I took the Tsukigi to a dyno day, it made .5 more hp then 2 equally equipped m14 equipped bikes, but still lost to SticksNStones m14 equipped zx14 (go figure). I believe the m10 made the least power of the group, but this was never backed up on the dyno, simply my opinion. For the muzzy m10, I tried my Tsukigi map, and a map for a ti-force (each of them complete garbage). Then I got the map from muzzys, and it was ok. Having this map on my bike made me realize that the mapping for the Tsukigi was actually pretty good. This was the worst mapped pipe I had. If I would have kept it longer, I probably would have gotten a custom tune. The brocks alien head was......surprise, surprise...... the best mapped pipe of the bunch. I got my maps from brock, and I never even considered getting it custom tuned. I got a dyno done (to check hp), and the tune was perfect. In my opinion, the street map worked best. I mphed lower with the race map then with the street map. When I got my Orient Express pipe, I just left the Brocks street map on the bike, and I have no need to change it. I have a map from hpc and from orient express, but I never even tried them out. The Brocks map is very smooth, even with the orient express map loaded. The Brocks sidewinder was not mapped very well for my area. It only comes with race map, and it simply did NOT mph like all the other systems. I suspect it was too rich, but I didn't keep the pipe long enough to find out for sure. It ran about 3 mph slower then my alien head and tsukigi systems. Perhaps I should have tried it once on mr9.......
Important note: I was comparing maps, and the muzzy and brocks maps were almost exactly identical. There were something like 14 different cells out of close to 500 cells. I'm guessing that muzzy just used brocks map, but it didn't work well for the m10 because it is not a stepped header design like the Brocks systems.
Pricing: These prices are the cheapest that I've found them
Brocks sidewinder: $1165 (comes with a good map, but seemed a little rich for pump gas and my elevation)
Brocks alien head: $1000 (but it comes with excellent maps)
Orient Express: $775 (the map looks pretty good that comes with it, but I've just been running the brocks map)
Tsukigi: $750 (doesn't come with a map, but the vender might give you one. The one from HPC is pretty good and he gives you the map if you buy the pipe from him)
Muzzy m10: $800
Conclusion: Don't get me wrong, I liked all of the pipes, but if I had to rate them, I would rate them.....
Orient Express
Brocks Alien Head
Tsukigi
Brocks sidewinder
Muzzy m10
This takes everything into account....... For my needs, the orient express looks the part, sounds great, fits the budget, and makes almost as much power as the Brocks.
Videos I have......
Brocks sidewinder:
Tsukigi
Brocks alien head
Muzzy m10
zx14 burnout from gilberjj on Vimeo.
Orient Express
zx14 going fast from gilberjj on Vimeo.
posted November 29, 2010 09:54 PM
gilberjj,
this is GREAT material, GREAT read, and i'm not even in the market for a zx14 system.
Big_T112
posted November 30, 2010 11:44 AM
A turbo is an exhaust, bolts on just like a header. You didn't add that one.
gilberjj
Friend of Fast
posted November 30, 2010 03:14 PM
True....... but it's not quite done yet.....
Compton
posted November 30, 2010 04:32 PM
brocks tiwinder with race baffle.
fit and finish is great. the blue coating is so so, no easy quick access clutch cover access, which sucks.
b.w.
epd345
posted November 30, 2010 05:30 PM
Nice Job Gilberjj, whens the Yoshi review?
gilberjj
Friend of Fast
posted November 30, 2010 07:28 PM
I've never had a yoshi system but I remember seeing an ivans dyne sheet saying they made good power. I can't get past their looks, but all japanese products tend to be high quality.
0.22422885894775 seconds processing time
