BIKELAND > FORUMS > ZX-14.com > Thread: Finally........ NEW TOPIC NEW POLL POST REPLY
Chaz
Currently Caged
posted July 18, 2010 12:12 PM
Finally........
I am finally putting some performance mods on my 2007 ZX14.
Other than lowering it 1" in the rear, tt has been basically bone stock since I bought it.
I ordered a Oriental Express Racing hi-mounted exhaust, with PC3 & K&N air filter.
It was a package deal, I believe the pipe is built & designed by Sato Racing.
I'm also having the flies removed, finally!
I also decided to get a new chain & sprockets.
I'm looking to keep the front sprocket at 17, and go up just one in the rear.
I'm looking for just a little more pull at the low end.
My question is would that be a good combo for the perf-mods that I'm adding, or should I just keep it at the stock gearing?
Btw-I don't race, I ride real mellow, well, most of the time........
2007 Plasma Blue ZX14, OER Hi-Mounted Full Exhaust System, PC3, KN Air Filter, GIPRO/ATRE, SpeedoHealer, Flies Out, FP Velocity Stacks, 0/+1, HotBodies Undertail, Lowered 1", ZG Dbl Bbl, ZX14 Chain Guard, Cox Racing Radiator Guard, HID Lights 6K-Lo / 8K Hi, Adj Side Stand, and a Stem mounted Valentine Radar Detector
gilberjj
Friend of Fast
posted July 18, 2010 12:16 PM
For street riding, I would keep the stock rear sprocket and put on a 16 tooth front. That was really fun on the street, and I didn't notice any loss in mpg. And yes, the high mount is made by Sato. Post up some pics!
Chaz
Currently Caged
posted July 18, 2010 03:06 PM
Thanks.
After looking at different possibilities on this website: http://www.gearingcommander.com/ ;
I think I'm going to go down to 16/40 ratio.
Thanks!
zixxer14
Damn that was Quick
posted July 18, 2010 06:48 PM
I'm running 17/42 on the street & like it better than stock. Even though it's not too much lower gearing I still find myself looking for one more gear sometimes when cruising the highway. It definately pulls better than stock and when on the gas it works great. Also it works with the stock chain length.
blackbullet76
posted July 18, 2010 11:13 PM
16/41 on the street is my setup. I like it!
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
Georgia14
posted July 21, 2010 12:13 PM
isn't that the stock setup? what's the diff?
2009 ZX14 with stock everything and
waiting on the warranty to run out to
upgrade.
Red1
posted July 21, 2010 12:20 PM
Georgia14,
17/41 is stock gearing.
Red12/Blue14
CraigChrist
BAWLS
posted July 21, 2010 11:28 PM
16/41 was a blast on the street, but if you drag race at all it's a bitch at swb once you add the pipe. Plus it's pretty much impossible not to ride like a complete hooligan all the time with that gearing lol :P
60ft-------1.42
1/8th------5.97
mph-------119
Hellmutt
at anything useless...
posted July 22, 2010 05:09 AM
I'm running 17/46 which is basically the same as 16/41 or close enough anyway.......it does pull damn hard low to mid and I find I'm shifting more often.........used to cruise thru town in 2nd at 3k -- now it's more like 5k.........mileage isn't too hateful on the pipelines either -- got a 75 mile round trip commute daily and still average in low 40's when I'm trying to behave
2008 ZX14 - Atomic Silver - Brocks SMeg - PC3 - BMC - Muzzy links - ZG DB - Cox rad guard - Buell pegs - Galfer lines ________________________________________________
LAB3
posted July 22, 2010 05:32 AM
16/43 with a stock chain. Kawasaki Zephyr 16 front and a black Driven 43 steel rear. 4000RPM at 70MPH in 6th. 180 top end :-) 60 in 2nd gear and hit, front tire WILL pull...... :-)
6th gear roll on's ROCK............ BIG difference from stock. Stock WB street ride only...so far.
Waiting on extended warranty to run out.
68gts2
hobbies ( Beating you !!! )
posted July 22, 2010 05:48 AM
17\43 is a really good street setup that does everything well. The added sweetness with this is when you look at the 10 percent the speedo is off from the factory combined with the gear change it just about equalls the removal of one corner of the speed sensor.
LAB3
posted July 22, 2010 06:04 AM
+1 then all my friends on their 14's did the same. I went 16/43 and I walk off from them 60 in 2nd and go thru gears. 6th gear roll on's same thing...see ya. Best performace gain for the $$ is gearing. I have the new model speedo healer that holds 2 sets of #'s. 180 GPS in 6th now
with 16/43.... fast enough for me on the street.
Chaz
Currently Caged
posted July 24, 2010 08:59 PM
Here's the rest of the mods that I'm adding,
HealTech SpeedoHealer
HealTech GIPRO/ATRE
FactoryPro Superflare Velocity Stacks
and removing the flies, finally!
Thanks for all of the input, and I've decided to go to a 17/42, and then, after awhile, I'm going to move down to a 16/40.
All of this, and coupled w/ the OER exhaust & PC3, I think it will be a noticeable change in power and acceleration.
Again thanks, all of the feedback was greatly appreciated.
-Chaz
LAB3
posted July 24, 2010 09:15 PM
HealTech GIPRO/ATRE
-Chaz
16/40 is not much different from 17/42 -1 on front is like about + 2 1/2 on rear.
Chaz
Currently Caged
posted July 25, 2010 04:40 PM
HealTech GIPRO/ATRE
-Chaz
Yes, I know.
Gearing Commander is great website!
Going from the stock 17/41 to a 16/40 would more of be a noticeable change, than just going to the 17/42.
So when I step down to a 16/40 from a 17/42 won't be such a big step.
Thanks.
LAB3
posted July 25, 2010 04:45 PM        Edited By: LAB3 on 25 Jul 2010 23:51
HealTech GIPRO/ATRE
-Chaz
Yes, I know.
Thanks.
Ok,
zixxer14
Damn that was Quick
posted July 25, 2010 08:32 PM
How the hell do you get 40mpg? I can't get 30, even if I pushed the fucker around!
01smokes
posted July 25, 2010 09:06 PM
i get high 30s low 40s on my turbo 14 and e85 i bet if it was on gas it would be in the high 40s. and thats no bull shit on the average its at 37mpg right now
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
Quick Reply:
0.284823894501 seconds processing time
