BIKELAND > FORUMS > ZX-14.com > Thread: Installing a pcv and removing the flies NEW TOPIC NEW POLL POST REPLY
dogg24
posted April 16, 2010 10:38 AM
Can anyone give me a shortcut to some links with pictures to help with this? Also what all do I have to remove to get the tank off? Also is there enough wiring on the pcv to put it under the seat and still hook it up with out extending the wires? I want to ground it where the battery grounds and it looks like I will have to extend the ground though.
2012 ZX14R SE, Streetmeg, PCV
thutch26
thutch26
posted April 16, 2010 09:03 PM
I guess your not wanting me to install it and remove the flies? lmk?
LAB3
posted April 17, 2010 12:05 AM
TThe screws are Not phillips. They are J.I.S. google this.
SixSixoh6
posted April 17, 2010 04:29 AM
i used my snap-on philips screwdriver to get them out....
LAB3
posted April 17, 2010 05:16 AM
Good thing, some owners have stripped the drive on the screws with less expensive phillips screw drivers.
68gts2
hobbies ( Beating you !!! )
posted April 17, 2010 05:44 AM
+1 on a long Snap-on phillips.
SixSixoh6
posted April 17, 2010 07:52 AM
oh yes, i would definitely recommend a set to everyone who doesnt own them. but im sure the JIS is a cheaper route lol
INTIMIDA2OR
RED rider!
posted April 17, 2010 02:14 PM        Edited By: INTIMIDA2OR on 17 Apr 2010 22:15
Basic fly removal pics:
'06 Passion Red ZX-14
*Lee*
FasterThanStink
posted April 17, 2010 03:28 PM
http://www.bikeland.org/board/viewthread.php?FID=27&TID=24193&set_time=
That's what gets you.
dogg24
posted April 18, 2010 11:42 AM
Thanks for the tips and the links everyone. I hope to start on the bike tomorrow since I had to work the weekend. I'll let you know how it went!
dogg24
posted April 20, 2010 12:04 PM
Well, finally got some time to work on the bike today. Got the flies out without to much trouble. Used a #2 8" Phillips to start but it was starting to strip the screw so I stopped. Then my buddy and I decided to use a #1 with the tip grounded down flat. All the screws came out without a problem between that and some heat!! Also was able to get the pcv installed as well. Didn't have to chance to ride it though cause I had to be at work but I'm anxious to see what the difference is. All together it wasn't to bad for my first do it yourself project. It feels good to do your own work!!
zxrider11
posted April 21, 2010 04:13 AM
If you haven't already, now is a good time to set your TPS and Accelerator Pump. With the PCV it is easy to do.
2008 ZX14 Atomic Silver
2012 KTM 690 Enduro R
68gts2
posted April 21, 2010 06:57 AM
I predict that Dogg is gonna be waggin his tail with happiness on his next ride.
Superman T
posted April 21, 2010 10:06 AM
+1 dogg24
dogg24
posted April 21, 2010 12:17 PM        Edited By: dogg24 on 21 Apr 2010 21:36
What exactly does the accelerator pump feature do and what do you have to do to set it? I called fuel motor USA where I got the pcv and they said the tps should be fine already, but what do you guys think and how do I set it if I need to?
68gts2
posted April 21, 2010 12:26 PM
Most maps don't use the fuel pump feature. I have just aquired a new map that does use it and will be installing it soon to compare it to my other maps.
68gts2
posted April 21, 2010 12:55 PM
Here's a link that will help explain the fuel pump feature. www.faic.cc. Its worth a look I think.
0.21536993980408 seconds processing time
