osr
posted March 25, 2010 11:04 AM
ZX10 wheel conversion for the ZX14 is finished
OK we got them finished ---
I am selling a kit to put the 06-07 ZX10 Wheels on a ZX14
Weight Savings :
Front wheel with one rotor
ZX14 14.8 lbs
ZX10 12.8 lbs
Rear wheel with rotor and sprocket carrier
ZX14 22.0 lbs
ZX10 17.0 lbs
Thats a savings of 7 lbs -- on the wheels alone!!!!
To do this kit you will need a few parts to add to our kit:
What YOU NEED: --
1. 06-07 ZX10 Front Wheel (this kit uses the stock zx14 front rotor/rotors.
2. 06-07 ZX10 Rear wheel -- complete with sprocket carrier and brake rotor.
3. 06-07 ZX10 Rear Brake Hanger
4 06-08 ZX10 or 07-08 ZX6r Rear Caliper
We will be selling to kits -- both are designed off a stock swingarm or extensions that utillized a stock zx14 brake hanger. If you have a different arm or hanger I am not 100% sure if it will work.
Our kit comes with the following:
All bearings, spacers and bolts to adapt both front and rear wheels to the zx14.
Street Kit:
$125 includes : All Bearings and spacers -- Exchange on modified ZX10 Rear Hanger
Grudge Kit :
$110 includes: All bearings and spacers -- no brake hanger needed we just make a bigger spacer.
$5 Shipping US MAIL
[URL=http://s212.photobucket.com/albums/cc79/osrbikes/?action=view¤t=DSC01027-1.jpg] [/URL]
[URL=http://s212.photobucket.com/albums/cc79/osrbikes/?action=view¤t=DSC01028-1.jpg] [/URL]
[URL=http://s212.photobucket.com/albums/cc79/osrbikes/?action=view¤t=DSC01753.jpg] [/URL]
[URL=http://s212.photobucket.com/albums/cc79/osrbikes/?action=view¤t=DSC01754.jpg] [/URL]
[URL=http://s212.photobucket.com/albums/cc79/osrbikes/?action=view¤t=DSC01756.jpg] [/URL]
Compton
posted March 25, 2010 12:09 PM
Will this work with two rotors on the front?
b.w.
osr
posted March 25, 2010 12:29 PM
yes front was the easy swap so that is no problem -- i just put the one on
INTIMIDA2OR
RED rider!
posted March 25, 2010 01:16 PM
'06 Passion Red ZX-14
*Lee*
Hellmutt
posted March 26, 2010 04:33 AM
Great idea..........you're making it easier for us all to convert offering a kit and doing all the work for us!! Thanx!!
68gts2
hobbies ( Beating you !!! )
posted March 26, 2010 04:47 AM
Shannon I wish you had had this available before I got my heavy stockers chromed.
osr
posted March 26, 2010 05:40 AM
No problem guys -- it seemed like there was a lot of interest in this conversion and no one really getting a kit together so here it is --
oilfieldtrash
Kawasaki enthusiast
posted March 26, 2010 05:51 AM
What do I need for the rear conversion? I could get a 06-07 zx10 wheel.
'07 white S.E. ZX-14 sold
oilfieldtrash
Kawasaki enthusiast
posted March 26, 2010 05:55 AM
I'm a noob but I could definitely get stuff I needed and take it to a reputable shop. I'm a street rider so I don't want to chance the front rim. Would that savings on the rear wheel help get the bike wound up quicker?
osr
posted March 26, 2010 06:02 AM
If you do the rear you need the complete wheel with sprocket carrier and and brake rotor -- plus the rear brake hanger and caliper.
Sprockets are available for ZX10 in a 530 conversion or ZX12 sprockets will work.
The front wheel is pretty much a direct bolt on.
You are loosing 5lbs off the rear
Rockhead2
Stevie's DADDY
posted September 28, 2010 06:43 PM
There's a 5mm difference in the triple trees between a 10R and 14.. You'll actually need to space the 10 rotors .100 a side for them to be a direct swap...... Just measured both front ends today.. As I've recently purchased both
posted September 29, 2010 01:22 AM
Rock, isn't that why you use the zx14 brakes on the zx10 wheel in the front?
gilberjj
Friend of Fast
posted September 30, 2010 04:05 PM
Does anybody know if there are differences between the 04-10 zx10 wheels? Why does Osr say they will only work for the 06-07?
oldkawboy
posted September 30, 2010 06:30 PM
I bought a set of '09 ZX10R wheels from a buddy and another friend wanted them for his '06 ZX10 (since they were black instead of bronze) and I swapped him and they bolted right up to his '06.
I bought an OSR kit and put on the '06 wheels on my 14.
I don't know about the '04 & '05 but I'm guessing they'll work......I dunno.
Dan
AcadianaZX
Advertiser
posted November 23, 2010 02:39 AM
Will the 14 sprocket bolts fit the ZX10 sprocket carrier?
James
AcadianaZX
Advertiser
posted November 23, 2010 08:50 AM
quote: Will the 14 sprocket nuts fit the ZX10 sprocket carrier?
James
DogoZX
posted November 23, 2010 04:14 PM
Edited By: DogoZX on 24 Nov 2010 00:31
quote: Does anybody know if there are differences between the 04-10 zx10 wheels?
'04-'05 10r front wheels have a different (smaller, I think) diameter axle. Rear 10r wheels are the same '04-'10.
quote: Why does Osr say they will only work for the 06-07?
I dunno. To my knowledge front and rear 10r wheels are the same '06-'10.
quote: Will the 14 sprocket bolts fit the ZX10 sprocket carrier?
Yes... but the 10r uses 6 nuts and the 14 uses 5.
AcadianaZX
Advertiser
posted November 23, 2010 09:44 PM
Thanks Dogo.
