Drewster
2008 Spec Ed
posted March 23, 2010 02:16 PM
Gearing sprocket combo???
I have a 2008 sp/ed with Brocks CT Duals,mapped "sec" (flies in coming out on w/end),BMC filter,PCIII stock w/base.16 toth front sprocket.
I went down a tooth on the front because it seemed too tall in 1st when riding through town / car parks etc, meant having to ride the clutch a lot going slow.
So I have a stock sprocket on rear and 16 tooth on front.
I know it is best to keep the front as large as possible for chain wear etc.
But if I go back to stock then up say 3 on the rear will my chain still fit?
What is the best sprocket combo for this setup eg flies out ,mapped, Brocks CTduals,BMC etc.
I dont drag race the bike but like to get up it when I can get away with it.
Wheelie
Old Man
posted March 23, 2010 02:22 PM
I like stock on the street
wee
SLVR_BLT
Chicken Strips!
posted March 23, 2010 02:24 PM
I know +2 rear fits but unsure of the +3 tho
Douglas Home
posted March 23, 2010 02:28 PM
I'm SWB and found it hard to launch on the strip at 16/41 so I went back to 17/41.
For street use you will enjoy! PM sent.
Doug Mackay Australia
Drewster
2008 Spec Ed
posted March 23, 2010 02:35 PM
Edited By: Drewster on 23 Mar 2010 22:36
Cheers
So BLT that would be 17t front 43t rear?
makenna
posted March 23, 2010 02:40 PM
Edited By: makenna on 23 Mar 2010 22:40
I stayed with the 17T on the front and went to 43T on the rear. It makes it a different bike and more fun to ride.
Zero issues on the street, thus far....
English is the only language that matters.
Drewster
2008 Spec Ed
posted March 23, 2010 02:52 PM
17/43 Would be a ratio of 2.52 "Makena"
16/41 Would be a ratio of 2.56 "Drew"
Would 17/44 or even 17/45 fit with stock chain?
I reckon a ratio of about 2.60 would suit.
Its not like you can do 250 - 300 everywhere!!!!
gilberjj
Friend of Fast
posted March 23, 2010 02:55 PM
I liked the 16/41 for the street. That's a 16t front and stock rear.
Douglas Home
posted March 23, 2010 03:03 PM
If you go 16 on the front get the rubber edged one from Kwaka, cuts down on noise.
Drewster
2008 Spec Ed
posted March 23, 2010 03:07 PM
Yeah I have the 16th non OEM one without the rubber edge and it is noisy!
SLVR_BLT
Chicken Strips!
Yes, the stock front sprocket with +2 rear will work on a stock chain. +3 might be pushing it since the chain adjuster is nearly at the max shortness setting.
ZX14Mike
posted March 23, 2010 06:52 PM
17/44 or 17/45 will require a new chain, even 17/43 wont fit till you get a few thousand miles on the bike and the chain stretches a little.
17/45 and 16/42 are GREAT all purpose street/strip ratios...........i've been running 16/42 since about 3 weeks after I got my bike almost 4 years ago and love it!
CraigChrist
BAWLS
posted March 23, 2010 07:09 PM
put it 7"+ over and go with 16/46 or 16/48 then take it to the drag strip lol .
60ft-------1.42
1/8th------5.97
mph-------119
ZX14Mike
posted March 23, 2010 07:11 PM
What are you running CC?
68gts2
hobbies ( Beating you !!! )
posted March 24, 2010 05:17 AM
17 43 is all the stock length chain will allow. Be aware that it will make your wheelbase as short as the slots in the swingarm allow and the bike will begin wanting to make the front tirm levatate easily.
posted March 24, 2010 05:26 AM
quote: put it 7"+ over and go with 16/46 or 16/48 then take it to the drag strip lol .
the only way to gear it! I wasn't gonna say it, but now that it's been brought up...
Superman T
posted March 24, 2010 05:29 AM
quote: 17 43 is all the stock length chain will allow. Be aware that it will make your wheelbase as short as the slots in the swingarm allow and the bike will begin wanting to make the front tirm levatate easily.
+1, power wheelies will be prone when you ride aggressively
LAB3
posted March 24, 2010 05:51 AM
I run 17/43 on a stock chain. I took about 2000 miles on stock chain before it stretched out enough for the 43 to fit. Sure made a difference from stock gearing. Perfect for a big
rider and street riding. Power wheelie in 1st gear sooo easy and will pull tire a little
in second gear roll on's at 60. And it will still go past 180 on big end. Great Street
gearing. 6th gear roll on's against stock gearing..see ya. Ask me how I know :-)
I purchased a Black steel Driven rear sprocket.
68gts2
posted March 24, 2010 06:24 AM
There Louis goes again, now this will be another sprocket brand thread. Ha ha
LAB3
posted March 24, 2010 07:06 AM
quote: There Louis goes again, now this will be another sprocket brand thread. Ha ha
Or a oil topic. I just could not help myself :-)
Louis
68gts2
posted March 24, 2010 08:38 AM
I am using the Super Spox 43 tooth that is a hybrid.it has steel teeth and an aluminum center for half the weight of a steel sprocket.Sorry Louis got me going though.
LAB3
posted March 24, 2010 09:06 AM
ummmmmmmm lighter. Start new thread, jacked this one ... sorry.
zixxer14
Damn that was Quick
posted March 24, 2010 01:12 PM
I run a 17/42 Black Drive System rear with Silver front & oil with Mobil 1 4T.
There, an oil/sproket thread jacking!
Superman T
posted March 24, 2010 03:08 PM
What a treat! Consistant though....
kawboy81
Busa Eater
posted March 24, 2010 03:35 PM
16/43, perfect for street if u ask me, plenty of low end ass to carry you from light to light should the occasional street race occur. I'm just sayin. Not that I would do such things lol
07 LE bolt on bike
